Question about Kitchen Ranges
Owners manual frigidaire stove model PLES399ECG operations manual
Door is locked, cant unlock it
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
  • 22 Answers
SOURCE: frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Posted on Mar 31, 2009
  • 113 Answers
SOURCE: door became locked by accident and I don't know how to unlock
hold in the lock button and try to unlock it
Posted on Apr 23, 2009
SOURCE: frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
Posted on Jun 06, 2009
How can I get my Frigidaire model FGF379WJCA is in lock mode with door open. How do I get it unlocked. I've had this stove for 14 yrs?.
Good Afternoon Friend, thank you for your post!
I recognize that the door of your Frigidaire range (FGF379WJCA) is locked with the door open. Here are two few simple troubleshooting tips that may help you resolve this issue:
    1.Press and hold the "CLEAR/CANCEL" button to stop any operating of the EOC (Electronic Oven Control). (Do this at the same time as step 2).
    2.At the same time, push and hold the light switch (typically located to the left of the door lock). This normally tricks the oven into unlocking the door.
This normally tricks the oven into unlocking the door. If these assessment measures prove to be ineffective, I would suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair your range. You can often locate an experienced technician in your area by going to the manufacturer website. Best regards! - Z
Sep 10, 2014 | Frigidaire Kitchen Ranges
Control lock preventing the operation of the stove
Hi Bruce, this is AP!
I understand you are struggling with the lock feature on your Electrolux duel fuel range, model EW30DS65GS. In order to cancel the Control Lock feature, press Control Lock and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing Control Lock and holding for 3 seconds. The Door Lock indicator light will flash for 20 seconds until the door has finished locking. Do not attempt to open the door while Door Lock is flashing, this may result in the door locking open.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.electroluxappliances.com/Owner-Support/Product-Support/
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Thanks,
Apr 02, 2014 | Electrolux EW30DS65GS Dual Fuel (Electric...
I have a Frigidaire Professional Series Stove. My red lock light will not go off. When I came down stairs it was on. I locked it & unlocked it and it's still on and my stove will not come on.
I looked up your model number and I would suspect a faulty door lock latch motor switch, part # 316464301.
It can be located my removing the back panel of the stove.
Aug 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
Here are all of the error codes and solutions for Frigidaire ranges: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Frigidaire Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My oven was accidentally locked while the door was opened and I do not know how to unlock it. I do not have an owners manual. I got the stove second hand. how do I unlock it so I can use my oven?
I unplugged the stove. Checked to make sure my motor fuse was still good and plugged in. I am not an electrician but I can read. Plugged it back up, and all was well.
Dec 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Jan 22, 2009 | Electrolux Frigidaire Professional Series...
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
