LXI television won't turn on
Television won't turn on with remote or power button. I have unplugged and replugged the TV.
  • Andrew Atwood Jan 19, 2009
    I bought a new TV and got rid of this one.
  • Andrew Atwood May 26, 2012
    I no longer have this tv
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Posted on May 27, 2012
  • 556 Answers
SOURCE: green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Posted on Sep 16, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
SOURCE: lxi television
I am looking for how to change my tv into video mode without the remote and found an answer for your problems....
Posted on Jul 17, 2008
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
  • 2992 Answers
SOURCE: the power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Posted on Apr 27, 2009
Why doesn't it stay on?
The power supply may be failing
Feb 11, 2016 | Sanyo DP26746 26 in. LCD Television
Only turns on with remote and won't stay on
Power button on the television itself may be stuck - go to the unit and press the power button se if it engages. If it depresses and sticks there is your issue - if it does not check the remote take out the batteries and unscrew the unit take the rubber pad out of the casing and spray out with canned air. If that doesn't do it - try unplug the tv from the wall for 1 minute or 2 and replug-in and see if the problem persist if so you will need to contact a tv repair shop but it sounds like the button on the tv needs to be cleaned because something is holding the power position in a spot to turn the unit off
Jan 14, 2013 | Mitsubishi WS-65411 65" Rear Projection...
1) tigh the springs contacts batteries with pliers for better contacts
2) open the remote control and clean the keypads from oxide, dust, etc, with alcohol, or contacts spry
Otherwise you must go to the repair shop TV for fix it.
God bless you
Jun 21, 2012 | Televison & Video
Remote control won,t work
This is how to complete a remote reset for a Sharp television:
Turn off the television if it is on. Unplug the television. Please leave it unplugged. Take the batteries out of the remote control. Leave the batteries out of the remote control. Is the television still unplugged? Yes? Good leave it that way. Are the batteries still out of the remote? Yes? Good leave them that way. Point the remote at the television's remote sensor. Hold the power button down for 30 seconds. Release it. Press and release each button on the remote control. Plug the television back in. Turn it on with the power button on the television itself. Replace the batteries. Try adjusting the volume. Hopefully the remote works. If it still doesn't work the remote sensor on the television could have gone out or you may need a new remote. may have a remote you can order or but if that isn't the problem you may or may not be able to return the remote.
Sep 23, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
The power/standby light starts flashing and the tv turns off
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 28, 2010 | Sony KDF-E42A10 42 in. LCD Television
AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Jun 21, 2008 | Televison & Video
Power off automatically, the red light in front of the tv blanking, remote / button can not shut off tv, only unplug the power. After 20 seconds replug the power, tv turns normal, but it happen again and...
Good Day,lizbg;
Check the solder connections at the negative side of both C809 and C810. Resolder if necessary. This a common problem with model.
Good Luck, Big Irish.
Jun 14, 2008 | Toshiba 42H81 42" Rear Projection...
Tv won't come on
for the last 2 months my remote will not turn my television set on or off, at first i could just press the power button to shut it on and off, now i have to unplug it for approximately 10 seconds, and then replug it and press the power button to get it to come, I found out that this only works though if your TV has been plugged in for at least two hours
Jun 01, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
