Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud humming dyson DC07
My Dyson makes a loud humming noise when first turned on and after about 5 mins it stops the noise and goes fine. Sounds like a vibrating rubber seal or something. Have pulled it apart and its seems to be down in the motor area.
  • Official Brand Answer
  • 2,572 Answers
Hi Phil,
I apologize for our delayed response. I am sorry to hear you are experiencing an unusual noise when you initially run your DC07. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone so we can also hear the noise to better determine next steps.
At your earliest convenience, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Posted on Dec 14, 2012
  • 3 Answers
SOURCE: Dyson DC07
your better bar is miss alined put a felt tab (for chair legs thier sticky) on the side if the bar near the belt on the inside end re put in the better bar no more noise
Posted on Feb 29, 2008
  • 97 Answers
SOURCE: Dyson DC07 works and cleans fine, but motor makes loud screaching sound.
If the screeching noise is happening at all times, it is most likely a motor failure; which unfortunately can only be resolved by complete replacement of the motor.
If it's a loud ratchety-screeching type sound, and is only occurring when the brush is set to carpet, it is most likely due to an obstruction of the brushroll or a problem with the clutch. Ensure that the brushroll can spin free, look for anything physically blocking it. Check the bearing ends on the brushroll, they can melt and cause the brushroll to not spin effectively. If neither of those two things resolves the problem, the clutch most likely needs replacement.
-R
Posted on Jul 31, 2008
  • 83 Answers
SOURCE: he dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Posted on Jul 30, 2009
tvservice306
  • 458 Answers
SOURCE: Dyson DC07 carbon brushes seem to be on fire when
need replaced Clutch Assy and Brushbar Assy
Brushbar Assy part no:904174-01
Clutch Assy part no: 900252-04
Posted on Feb 14, 2010
Dysonteam
  • 167 Answers
SOURCE: my dyson 17 dc is making a noise like a loose
Hi there, your machine is designed to make a ratchet noise if the brush bar is obstructed.
Please check to ensure that there are no blockages around the brush bar and that any hair or threads have been removed. If you need help with this, you can follow our self help guide in the support section at www.dyson.com.
If you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
DC07 grinding noise
I had the same problem with mine, I took it to a repair shop. The problem is where the belt passes through from the brush and goes inside the machine. Move the belt over a bit and you will see that a plastic guide has been bent over and is pressing onto the brush, which causes the noise. Just bend it straight again and it stops.
Apr 21, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 makes loud vibrating loud noise
Sorry to hear about the problem you're having with your DC07. Your cleaner is equipped with a safety feature which makes a ratchet noise if the brushbar gets jammed, to warn you to clear the obstruction.
For help checking for and clearing obstructions, you may find it useful to visit www.dyson.com and click on 'Support'. This step-by-step illustrated guide shows you the easiest way to clear the brushbar:
http://www.dyson.com/support/help.asp?article=5&product=DC07-SY-HEPA_US
If you've followed this walkthrough and your DC07 is still making a ratcheting noise, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide you with the assistance you need.
Kind regards,
Jack
Jul 25, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Makes a loud noise like something is impeding the
I would try changing the belt. Even though the belt may look fine it can be stretched or worn and that can cause loud noises. You can get dyson belts here:
http://www.vacbelts.com/dyson.htm
Oct 28, 2009 | Dyson Vacuums
Loud Noise when on
Sounds like something is caught in the fans.  If they are found to be damaged, replace them.
Nov 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07
First, check all of the ports, there are various covers you can take off to see if there is a clog, also check the hose for a clog. Make sure all filters are clean out. The worse case would be a motor problem.
Feb 14, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
108 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
