Question about Woods Indoor 24 Hour Night Light Timer (49644)
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
  • Woods Master
  • 5,245 Answers
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Posted on Nov 28, 2012
  • Gene Haynes Nov 28, 2012
    5) Din rail 1 hour cycle timer Talento 121 and FM1S12HU-120 timers rated for 60Hz US market. 1.25 minute trippers would mean 40 trippers = 50 minutes http://waterheatertimer.org/pdf/025-Tale...
3 Suggested Answers
SOURCE: Hi, I buy a timer
Hi claug,
Add a comment with brand and model number for best recommendation.
Or open following link to identify timer, and then add a comment.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Posted on Apr 17, 2011
SOURCE: Describe your INDUSTRIES 59112
1) Thank you for the model number.
Question posted under oval-shaped Woods 59112 timer.
This timer has minimum 5 different product numbers, and has also been misidentified by sellers as 59203, plus Westinghouse has two similar oval timers with 2 additional product numbers.
Open following links to identify timer and download possible manual:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Typically: Always come to fixya when searching for a manual, and describe product and include product number for best possible result.
3) When searching for on-line manuals:
a) put quotation marks on search parameter: For example "59112 manual" or "59112 timer manual" or "59112 timer"
b) do a google image-search for 59112 timer
c) I usually image-search first to identify product. And then google search with instruction .pdf
So search would be: 59112 timer manual .pdf -or- 59112 timer instruction .pdf
4) Generally, except for industrial timers that have replacement PC boards, there are no repairs for defective timers.
5) Plug-in digital timers have replaceable battery, or have rechargeable battery.
Last step troubleshoot is to replace battery and reset timer.
The rechargeable battery is not replaceable
If timer function is not restored afterward, then timer has gone bad.
6) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 09, 2011
I need a light timer that I can set to be on for 50 minutes and off for 10 minutes, and repeat this over a 24 hour period.
Another timer that can be set this way is the Intermatic ET9000 series commercial programmable 365 day timer, which accepts any voltage, and rated 20-30 amp, and has 4000 set points for programming.
http://waterheatertimer.org/pdf/Intermatic-ET90000-Series-Spec.pdf
Another timer series might be useful, and can be programmed by computer and has small relays that install on a card that is installed in computer like installing a modem card, and can interface with zigbee wireless:
http://www.francisav.com/relay_controllers.htm
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
The manual timer in the picture has 120 minutes on it . the discription says it's a 240 minute timer. what is it?
Timer is not identified.
Add a comment with in-focus photo of timer posted on flickr, or describe all details about the timer for possible help.
240 minute timer could be a cycle timer that repeats timing cycle each 4 hours.
Tork 8000 series cycle timers have 6 minute to 1 hour
Intermatic cycle timers range from 10 minutes to 4 hours
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/specialty%20time%20switches/c8800%20short%20range%20cycle%20timers.aspx
Adjustable cycle timers, percentage cycle timers have variable time settings that span 1 to 24 hours.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=cycle+timer&op=search&Ntt=cycle+timer&N=0&sst=subset
Jul 18, 2011 | Hardware & Accessories
Can not set up my hydrofarm timer to come on for 1 min and off for 5 min.
You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
Jun 05, 2011 | Hydrofarm Timer 24 Hour
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Setting
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Woods Indoor 24 Hour Night Light Timer (49644) Logo
164 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
