Question about Locks & Locksmithing
Brinks keyless deadbolt Model No.: 4303-119-2
2 Suggested Answers
SOURCE: i have a kwikset deadbolt
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
How do I remove a brinks deadbolk lock from door
1. Open the door.
2. Unscrew the 2 screws on the inside and the 2 screws on the edge of the door.
3. Pull the thumb turn off, pull the outside cylinder and ring off, and pull the deadbolt assembly out of the edge of the door.
4. Unscrew the strike plate from the door frame and remove it and the plastic thing behind it, if it was installed.
5. Throw the whole thing in the trash. I wouldn't even reuse the screws!
Feb 18, 2015 | Brinks Combo Pack Deadbolt & Keyed Entry...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a keyless weiser deadbolt. Can't find any model # but bar code inside reads 0550B05755CC. Has worked well until I tried to lock going out and only got long beep. Tried to recode and will not open or...
Very common for the keypad to stop working.
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
Dec 08, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Locks & Locksmithing Logo
350 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
