Question about Canon PowerShot A85 Digital Camera
I have a A85, whoo can help me get Chinese manual
I need a Chinese operation manual
  • 15,935 Answers
Please look here, but as I do not speak or Read Chinese, you will have to do the footwork.
Look for a Support & Download page, and enter your make & Model # to get the manual for your Camera.
Hope it helps.
http://www.canon.com.cn/
Posted on Jan 10, 2009
I have just received my new phone its a samsung galaxy on5 sm-g5500 and its all in chinese can you help
Contact anyone in China. There is no other way. Chinese Women are the best to contact. They are very co-operative; you know?
Sep 07, 2016 | Samsung Cell Phones
Some whirling noises
suspect it is warped disc rotors. If the pedal pulsates under your foot on light braking I would take it to a brake shop for investigation of the fault. Any noise or unusual incidents with brakes can become critical if ignored.
Jun 10, 2013 | 2006 Mitsubishi Outlander
My canon A85 has suddenly changed its language to chinese.. I want to revert it to English
Turn the camera on. Press the MENU button. Use cursor-left/right to select the wrench-and-hammer icon. Use cursor-up/down to select the speech-bubble icon. Use the cursor buttons to select "English" and press the SET button.
Sep 06, 2011 | Canon PowerShot A85 Digital Camera
Is there a chinese manual for the latest imac? even in PDF would be great! thanks
Apple doesn't even supply an English manual for the iMac. You are expected to use the Help facility on the menu bar to find out how to do whatever it is you are trying to do, whether you are in the Finder or in the various applications. These help documents are provided in numerous languages, including Chinese, which will appear if you operate the system in Chinese.
Feb 22, 2010 | Apple 24" iMac Desktop
Fridge does not get cold, lights are flashing and whoo whoo noise
Lights which previously did not flash but now do are clear indicators of operating failure.
Refridgerators and freezers do not like being unplugged for too long. if yours has been disconnected from the power for more than a couple of days, it could be damaged and need part replacement.
The variables are cold leakage, cooling gas leakage, electrical pump failure, thermostat circuit open, thermal cut-off switch disconnected. All of the above can be dangerous - electricity, gas, over-working pump etc. so always remember what we learned in kindergarten - If in doubt don't' - good advice with anything risky.
If you set the fridge on the coldest setting, place a common thermometer inside, note the initial temperature after closing the door for 15 minutes and then leave the fridge door closed overnight, in the morning carefully touch the heat transfer coils at the back, they should be hot all over to the touch. Open the door and check if the temperature has dropped.
If the whoo whoo noise is coming from the pump (often located in a black closed saucepan-sized unit you need to contact a qualified Whirlpool fitter.
If the whoo whoo noise is coming from around the edge of the door, the airtight seal is possibly defective. The seals often get dust etc. trapped in the accordian-like sealing strips around the entire door so, being careful not to damage the seal, clean the inner grooves - an old toothbrush and household cleaner generally work well.
If the fridge is a self-defrosting type, the lights may be indicating that it is stuck in defrost mode - check the Whirlpool website for troubleshooting temperature settings. There is often a small regulator switch which can break down. If you think that this is where the noise is coming from do not go fiddling about - electricity is a to be treated with care. Look for scorch marks or listen for crackling noise indicating a short sparking. Unplug the fridge before poking around the wires. A connector may have been dislodged and needs to be reattached so double-check that the power is off before reattaching the loose wire. It should be obvious where it plugs in but if not, don't go touching different tabs.
Re-read the installation and operating manual or call a fridge repair service if you are unable to find the fault. You can save time and repair costs by telling the repair person what you have tested and the results.
The built-in thermostat could be malfunctioning and preventing the coolant coils to absorb heat.
Sometimes the defrost drip tube can become blocked. This generally runs down the back into a drip tray. You should be able to check for blockage by thoroughly cleaning the tray end of the tube and blowing through it. Don't ****.
I hope this helps,
jenni.
Sep 09, 2009 | Refrigerators
Need a manual on how to operate the canon A85 digital camera.
The A85 is a nice camera that takes great pictures. Heres the Quick Start Guide, directly from Canon:
http://gdlp01.c-wss.com/gds/0900001275/PSA85QSG-EN.pdf'
and here's the full User Manual:
http://gdlp01.c-wss.com/gds/0900001271/PSA85CUG-EN.pdf'
By the way, if your camera ever starts taking distorted, off-color, or black pictures, please see the following two links as Canon will repair it for free with free shipping:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2009 | Canon PowerShot A85 Digital Camera
Thumping
Best way to know is to lift the wheel up and spin it while putting your hand on the strut and you'll feel if there is a rough sound resonnance on the strut while turning the wheel.
Cheers
Nov 19, 2008 | 2000 Daewoo Nubira
My manual for my Emmie #544 got destroyed. I need a new one.
I have one thanks to my e-mailing a user that posted the question 3 yrs ago! Whoo whoo. I can e-mail it to you & anyone else. Here is my "unregular" e-mail - RDNKBIKER@aol.com. I know it's dangerous to put my e-mail out there & I have excellent virus protection so I won't be sending anyone any "bugs." =) Just be sure to put "Emmie 544 manual" in the subject or I will simply delete it.
Nov 19, 2008 | Food Processors
Canon PowerShot A85 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
