Question about Wildgame Innovations N2 IR 2.0 MP Digital Scouting Camera
Stolen SD Card. How do I view pictures with USB?
Can I view the photos on my SD card on the camera and not use USB cord, or do I have to put SD card in computer?
Yes, most cameras allow you to view pictures on the camera! Obviously viewing on a PC screen would be clearer because of the screen size compared with the smaller camera screen!
Feb 15, 2015 | Cameras
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
Whant show pictures
Get an USB card reader, insert the SD memory card into the USB card reader and then connect the cable from the USB card reader into the USB port on your computer. Your computer will see the card reader and SD memory as an external storage device, click on this drive and open the folders on the SD memory card to view your photos.
Aug 09, 2012 | Computers & Internet
Memory card trouble
The camera should have come with a USB cable with which to connect the camera straight to the computer. Connect the camera (with the memory card inserted) to the computer and see if you can access the photos.
Jun 15, 2012 | Nikon COOLPIX P100 Digital Camera
Black screen on pictures. can view old pictures on card.
if your camera has SD card you have to remove it and put it in memory card reader , plug it into computer, there you can view and copy your pictures. or if you have connector to your camera to usb potrt.
Aug 30, 2011 | Samsung BL103 Digital Camera
I had my SD card for my phone & i was going to switch phones. so i changed my SD card in to a Samsung focus. Nd as i tried to put it back in my old phone it wont read anymore. i have lots of pictures i...
plug it into your pc/laptop via sd card slot (adapter needed if its a micro sd) or through a usb memory card reader. open folder to view files, then copy and paste/drag and drop the files you want into a folder on your desktop.
Aug 05, 2011 | SanDisk 2GB microSD Memory Card
In pictures format where does the sd card go for the tmobile htc G1 phone
Hi Elizabeth617,
Here's how you access the pictures from your SD card:
  • Connect your G1 to your computer via USB
  • Pull down the notification menu and select "USB connected: Select to copy files to/from your computer."
  • "Turn on USB storage"
  • Now open your phone in a folder on your computer
  • You will see a folder that says DCIM (This is where your pictures are stored)
  • Open DCIM and view the pictures in the folder Camera
Mar 05, 2011 | HTC G1
Cannot get pictures from my camera
If you can view the pictures on the preview of the camera itself then the pictures are safe. It is possible the photos reside in the INTERNAL camera memory rather than on the SD card. You may have to have the camera transfer them.
It is also possible that the SD card is NOT compatible with your camera.
What I would do is to procure a seperate SD card reader (they are very inexpensive) and remove the card from the camera and read it using the external interface.
NOTE: There are high density SD cards that are usually not compatible with older cameras... they are marked HD.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Panasonic Lumix DMC-FZ20 SD Card Reading Issue
Plug you camera into USB. Go to My Computer and find a drive device named External Drive or USB Storage etc. Click on this and you should see a folder named DCIM (digital camera EXIF standard Digital Camera IMage folder. This is your cameras memory card.
Click on this and find a subfolder(s) named according to manufacture. For Panasonic it would be 100_PANA or maybe 101_PANA. These are you picture folders. Click on one to find pictures. Drag and Drop folder to computer to download them.
May 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Wildgame Innovations N2 IR 2.0 MP Digital Scouting Camera Logo
23 people viewed this question
Top Wildgame Innovations Cameras Experts
teddyboy
Are you a Wildgame Innovations Camera Expert? Answer questions, earn points and help others
