Question about Philips Fr965 Stereo Receivers
Philips fr 965 wont stay on
When i turn it on it is on for like 5 seconds then says power off
    Sergeant:
  • 344 Answers
It is shot, Kiss it good buy, Repair will be verry costly, Just go end get a different one, End not anouther (Phillips)
Posted on Nov 29, 2012
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: where is the fuse on
Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
Posted on Jul 15, 2008
hmerchant110
  • 7191 Answers
SOURCE: Where can I get an
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Kindly let me knnow if you have any difficulty in downloading the manual
Thanks for using FixYa.
Posted on Oct 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have Phillips home theater
It's not a fuse. Fuses don't self-heal allowing another try.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
How do I connect a Philips FR 965 digital
http://www.p4c.philips.com/files/f/fr965_00/fr965_00_dfu_nor.pdf Here ya go.
Oct 01, 2014 | Audio Players & Recorders
I have Phillips home theater system model FR 965. When I turn the power on it powers up for a few seconds and then shuts off. I have done some searching online and found advice saying that it may just be...
Jun 11, 2011 | Philips FR965DHT Receiver
My 36'' Philips tv shuts off after about 5 seconds after I turn it on. The on light stays on but the tv doesn't.
ive had many problems with mu three philips tv and every repair on them was very exspensive they are unfortunately throw aways never buy one again. ive lost thousands..
Jan 28, 2010 | Philips 36PT842H 36" TV
Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
May 23, 2009 | Philips Magnavox MS3652S 36" TV
Does the phlips fr 965 have a fuse
If the unit was purchased in the UK, then yes it will have a fuse witht the following specs:
BS1362 5 amp, A.S.T.A or BSI approved type
Otherwise, I would suggest that you bring it to an authorized repair shop.
Feb 28, 2009 | Yamaha HTR-5730 Receiver
Power wont stay on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
The run the Repair and the Update in Philips Device Manager.
Jul 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Where is the fuse on a Philips FR 965 AV receiver
Hi Hibbs8829
regards
robotek
Jul 15, 2008 | Philips Audio Players & Recorders
Philips Fr965 Stereo Receivers Logo
212 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
