Question about Technics SA-DX1050 Receiver
SA-DX 1050 overload
I recently moved my 11-yr old unit to a new TV stand and it goes into overload when i turn up the volume for just a short period. It does seem to be relatively hot inside the shelf, but i can't tell if the fan is running or not. I tried leaving the door open but no luck.
    Sergeant:
  • 344 Answers
The old gal might be leting you no its time is comeing to quit, TO put it mindly, They only last so long, For the cost of repair nowadays to replace output transisters , YOU CAN BUY A PRETTY DECENT NEW UNIT,
Posted on Nov 29, 2012
  • ropester57
    ropester57 Dec 05, 2012
    You may be right about that. i moved the unit outside the cabinet with the same results. FYI, the cooling fan doesn't appear to be working but i haven't checked to see if it is the fan or not. Still, i concur that it's time for a new unit.
5 Suggested Answers
SOURCE: Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Posted on Sep 15, 2007
SOURCE: I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Posted on Jan 17, 2009
  • 1525 Answers
SOURCE: Technics SA-AX7 OVERLOAD problem
hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
shaun
Posted on Oct 01, 2009
gregs_rockin
  • 274 Answers
SOURCE: need to purchase a controller for technics sa-dx 1050 dvd
Any decent universal remote will work on it and control your basic functions.
Posted on Oct 15, 2012
It'll work listening to the radio just fine for about 5 minutes, then the sound goes away.
If you are running at high volume for even a short period of time, the overload signal to the microprocessor(computer within your unit) will cause the unit to shut down. If you are running it that loud, try turning the level to 1/3 of your normal listening mode. If it runs, try to keep the volume with reason.
Aug 04, 2015 | Audio Players & Recorders
Why am i getting an overload message when i don't have anything connected to it ?technics sa-dx 1040
double check there isn't a piece of wire that has broken off the speaker cables and is shorting two of the speaker terminals together. The unit needs to be turned off and unplugged for a minute to reset the protection circuitry. If this doesn't fix it, there's likely an internal failure.
Dec 22, 2014 | Technics SA-DX1040 Receiver
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-DX940
Jan 25, 2007 | Technics SA-DX940
Overload?
From the manual, you may have seen this: Switch off the unit, determine and correct the cause, then switch the unit on. Causes include: ?Shorting (bare wires touching) of positive and negative speaker wires. ?Using speakers with an impedance lower than that rated for this unit. ?Straining of the speakers through excessive volume or power. ?Using the unit in a hot environment without proper ventilation.
Dec 01, 2006 | Panasonic SA-HE70 Receiver
Overload
Firstly check all your speaker wiring. Any damage can cause a short which will overload the system. You might not notice it, due to the fact that when you have the system on loud, vibrations move the wires on the cabinets or elsewhere. So make certain there are no loose wires near the speakers terminals into each one. If all that is good go to the next check.
Check If the amp is getting VERY hot when the overload occurs, then it might have a faulty part(s) on it. This might have occurred if you have been using speakers that never did match the amps requirements in the first place.
Mar 12, 2017 | JVC RX-668V Receiver
Technics SA-DX1050 Receiver Logo
128 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
