Question about Miele Optima G2430SCi Stainless Steel Built-in Dishwasher
F70 error on Miele G2432 dishwasher - Miele Optima G2430SCi Stainless Steel Built-in Dishwasher
5 Suggested Answers
  • 177 Answers
SOURCE: fault code f70, drain pump keeps running, nothing else works
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Posted on Jan 25, 2010
  • 177 Answers
SOURCE: 2 year old miele dishwasher runs without being turned on.
hi,
A F70 fault is the float switch in the base of the unit which is activated due to water in the base. you may have used too much detergent or the wrong detergent causing the unit to over sud or you have a genuine water leak. the continous running noise is the drain pump trying to remove any water.
you need to remove the bottom panel, turn the power off and dry up the water with a towel. then run it again and see if you can see a leak.
hope this helps
Posted on Jun 06, 2010
rickead1
  • 1998 Answers
SOURCE: dishwasher was turned on for a wash then there was
im going to have to write this in two posts there is a long amount of things to check with remedies
F70
Float switch fault
After the WaterProof System has activated, the program is interrupted and
the drain pump is operated. The fault will be indicated in the display or via
LEDs. The buzzer is activated for as long as the fault is detected.
Note: The drain pump continues to operate even after the appliance has
been shut off. The drain pump can only be deactivated by disconnecting the
power supply connection.
Cause:
Water in the drip pan. Changeover contact of overflow float switch B8/3
closed from 1 to 4 (refer to the wiring diagram).
Remedy:
1. Remove the water from the drip pan (e.g., with an absorbent cloth).
Note:
Upon opening the appliance and removing all water, there should be no
smudges, smears or traces of deposits. Take pictures of any deposits, if
possible, and note their type (rust, calcium, detergent, or salt?).
2. Check all hoses, connections and threaded unions for leaks.
Posted on Jan 16, 2011
  • 16043 Answers
SOURCE: F70 plus not draining completely
check for obstructions in the pump, the hose and the drain.
Posted on Sep 26, 2012
Sep 25, 2012 | Miele Dishwashers
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
What does the fault F70 mean for a Miele G 1534 Sci dishwasher, please?
hello,
The code is an indication of a problem on the washer
F67 means the input voltage on the microprocessor is incorrect. Code F70 indicates a problem with the water temperature sensor circuit. F76 means the NTC temperature for the cold water valve is over the limits.
thanks.
Oct 26, 2010 | Dishwashers
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
Miele dishwasher error message F70
Hello, I hope you remember me, we just had a Live chat session on Fixya, about the Miele DishWasher.
I request you to please Login back to your FixYa account and on the top right corner you will see a 'My Profile' link, go there and find the chat we had.
And kindly leave some feedback after accepting the solution, as that will be useful for FixYa's future reference.
I hope you will spare some time for this. We will feel obliged.
Concerned, WAQAR.
Mar 13, 2010 | Microwave Ovens
F70 fault error keeps appearing on my Miele G1220SC full dishwasher - any idea?
it is the float switch in the base of the unit, which registers a water leak. you are probably using too much detergent and it is overflowing into the base.
Oct 31, 2009 | Zanussi 24 in. DE6850 Free-standing...
Fault code f70, drain pump keeps running, nothing else works
Hope this helps.
May 29, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Miele Optima G2430SCi Stainless Steel Built-in Dishwasher Logo
94 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
