Question about Toshiba Satellite P25-S5093 Notebook
Toshiba P25 cannot read cd
Reinstalled OS, Updated EVERYTHING. Cannot read a CD or any software disks, or DVDs. The entry in My Computer says DVD-RAM and I am unable to change it. I enabled CD writing in Properties, Recording but no change.
  • destructo240
    destructo240 Nov 29, 2012
    I reset the BIOS, and I can now boot from the original software DVD. When I put the disk in while the system is running, the description changed to a CD, but as soon as I remove the DVD, the description reverts to DVD-RAM. I have reseated the drive, without any change to the symptoms.
  • Toshiba Master
  • 2,878 Answers
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Posted on Nov 28, 2012
Testimonial: "Thee information was helpful and accurate. However, it didn't solve the problem. I probably deleted some software that was responsible for the drive acting the way it does. I have resigned myself to re-installing the OS. This time I'll leave it alone. Than k you very much for your help. "
  • destructo240
    destructo240 Nov 28, 2012
    I followed all instructions. The computer initially loaded software from the drive. Later, the drive appears as DVD-RAM in My Computer. BIOS recognizes the drive. Now I can't even boot to a known good bootable CD.
  • Jose Diaz
    Jose Diaz Nov 28, 2012
    Is it possible to re-seat the drive on this model?
5 Suggested Answers
SOURCE: TEAC DW-224E-B [CD-ROM drive]
Fail could mean a lot of things but those diagnostics (If I remember correctly) look at hardware. If you have a more concise message than just fail (I seem to remember they were) and it points at the cd/dvd first check the connection and if you happen to have an old cd player around try it...if it works and the other does not you have solved the problem. There is more to this but try this first .....FYI...if you were thinking of upgrading to a lightscribe or just wanted to have an extra CD ($10) it may be in your time interest to get one. Much more could mean anything from a bad cable to motherboard problem to....???? This is a start only....let me know....Tango
Posted on Jan 25, 2008
freetek
  • 5568 Answers
SOURCE: dvd rom not reading dvd while reading cd properly!!!
The demands on the drive differ greatly for reading CDs & DVDs.
This is a common problem since alignment of the drive is very critical for DVDs and often fails first.
I don't offer much hope, but you might buy a special disk for cleaning optical drives; sometimes they will help.
This article has some tips that might be of use:
http://www.smartcomputing.com/editorial/article.asp?article=articles%2F2003%2Fs1409%2F10s09%2F10s09.asp
Posted on Aug 03, 2008
ser71
  • 818 Answers
SOURCE: Toshiba Satellite A105 PC Notebook, DVD/CD Drive.
You can't just change it from pio to udma. Go to Control Panel, System,Hardware,Device Manager, then expand IDE ATA/ATAPI, then right click on Primary IDE and select uninstall. Do the same for secondary IDE. Then just reboot your system, and it will autodetect all IDE devices. After that when you check, you should not have any devices in PIO, and your burner should work correctly. If not, stick it in a hyperbaric chamber for 2 days and see if that helps. smile.gif __________________
Posted on Jul 12, 2009
  • 5 Answers
SOURCE: R500 laptop doesn't show/recognise CD/DVD drive
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs http://support.microsoft.com/kb/314060
download and run fix then reboot
Posted on Sep 02, 2009
My toshiba equium a200-1v0 will not burn to dvd
Does it read CD/DVDs fine? If so, the laser head for writing data to the discs may be defective. Also, keep in mind that when CD/DVD drivers start to fail, they may be able to read/write to CDs and not to DVDs or vice versa.
Otherwise, go to "Start" and right-click on "Computer" and select "Properties". Then, on the top left corner of the window, go to "Device Manager". Expand "Disk drives" and make sure there is no exclamation mark or question mark on the CD/DVD device. If there is, then either the driver software is missing/corrupt or the drive is defective. If no CD/DVD drive is listed, then it is not being recognized as being installed then check all of the cables to make sure nothing's loose, otherwise it is most likely defective.
May 05, 2011 | Toshiba Computers & Internet
How do i replace harddisk in my toshiba p25 s487
Ensure you have your backups up to date and either OS disc or rescue discs to place a new system on your new hard drive.
Remove the larger cover from the underside of the laptop, slide out the hard drive. Remove the old drive from the cradle and fit the new drive to the cradle. Slide it in.
Power the laptop up open the DVD drive and place your restore/PS disc in it and on the bios menu select F12. Set the boot device to DVD/CD.
Boot from the DVD/CD drive and follow the prompts.
When finished, download updated drivers from www.toshiba.co. and restore your backups and programmes.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite P25-S487 Notebook
My Samsung SH-S182m dvdrw will burn files and video, and read cd's, but will not read dvds, even the ones I burn. I have updated the firmware trying sb03 , 04, 05 and the latest 06. Still no reading dvd's....
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Jan 10, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
CD / DVD ROM problem, can read cds or dvds that I create
Sounds like your need to install the codecs. Here's a good set of them: Download the full version and you might also want to check your dvd decoders,
http://www.free-codecs.com/download/K_lite_codec_pack.htm
May 20, 2009 | ASUS R1F-K049E Tablet PC
My Toshiba SD-C2612 8X Slim DVD will not read cds. I just updated the firmware in my laptop for this drive and it still wont read cd's. get can not read d: error. I reinstalled it and everything.
Try a lens cleaner, probably wont solve the problem, the drive's optics for the cd side are failing dvd's still work, if you must read cd's replace the drive or use a external cd drive.
May 01, 2009 | Computers & Internet
DVD rom can;t read from first cd
I have had the same problem many times. Solutions can vary but the first thing I would do is use a cleaner/repair on the CD. The ones you use on movie DVDs will work. If this does not fix it, there might be lint or something on the laser light. I use one of the Q-tips on a long stick to gently clean the light area. If this does not fix it, I usually resort to installing another DVD. Or you may be able to use one of the external DVDs if your computer recognizes it as a boot device.
Oct 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Console button(s)
First u need to repair ur OS
Oct 25, 2007 | Toshiba Satellite P25-S607 Notebook
Toshiba Satellite P25-S5093 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
