Question about Dryers
Dryer Problem took srwes out of back. think that I may have thrown my dryer out of level. cant get screws to line back up.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
Cant fasten filter back in
Check inside the filter housing for obstructions
line up the slot inside the filter housing with the filter then screw it in clockwise while gently pushing
May 31, 2015 | Bosch Washing Machines
How do I level the dryer
What is the model number of the unit?
Nov 28, 2012 | Dryers
How to line up screws on back of frigidaire dryer
You gonna need to take the drye apart and put the heater pan back in place. If you try and operate it now you gonna mess up the heater. My heater replacement video shows how:
Here is my page which shows Frigidaire dryer repair videos.
Nov 16, 2012 | Frigidaire GLER331A Electric Dryer
My belt came off its not broken just came off i took the back off i took the top off still cant get to the belt
Frst take the two screws that are exsposed after you remove the lint trap. Next use a flat bade screw driver and insert it in the seam between the front and top approximately 2 inches in from the side. There is a spring clip 2 inches in on each side you have to trip by shoving the screwdriver in about 1 1/4 inches. The easiest way is to tap them with a hammer. (pry upward on the top and lift it all the way up it will be hinged on the back. Now looking down each front corner you will see a 5/16 screw approximately 8 inches down from the top. Remove these screws and the front can be tilted outward and lifted straight up. You will see a door switch and wires attached to the front remove the wires. You need to do this so you can put the belt around the drum and slide it back. You can see where the belt was riding on the drum. Set the front aside and out of your way. (if you are a very flexable person you can replace the belt from the front but us normal human beings have to remove the back) Next go to the back and remove the back panel there are several 5/16 hex head screws around the outside edge of the back panel remove them and set the back panel aside. Inside on the bottom left side as you face the back of the dryer you will see a motor and a tensioner. The tensioner may still be in place it goes in a slot in the bottom of the dryer next to the pulley on the motor. Put the belt on the drum by putting it around the drum from the front. The belt goes around the drum across the pully on the motor with the tensioner and its pully putting tension of the belt to take up any slack. Then just put everything back in reverse order. Make sure the tensioner pully rotates smoothly if it does not this can cause your belt to break or usually get thrown off the pully. Remember to unplug your dryer before starting and clean the excess lint out of the bottom of the dryer as a good prevention to other problems. I hope this helps
Aug 25, 2010 | Dryers
Front panel not fitting properly
HI, This model does not have screws at the bottom. There should be small tabs that the front locks on the front frame.
Slide the front panel bottom against the cabinet and then push the top of the front panel against the drum. I hope this helps you. Please let me know if I can assist you further.
Vic
May 26, 2009 | GE DBXR463EDWW Electric Dryer
I took apart and cleaned out my sr 125 carb but cant remember
Seat both screws lightly then go one and one half turns out. If no go, then remove the screws and check for any nicks, score lines or slight depressions around the end of each screw. ANY deformity on the screws dictates that it is time to replace the screws.
Apr 05, 2009 | 2001 Yamaha SR 125
MODEL LEQ2152Y DRYER
Put a bolt in one hole slightly started. then a small screw driver in the other hole opposite side. then put the rest in
Feb 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
CHANGING A BELT
I'm looking at the same problem with my Kenmore. You access from the front on mine. I had two screws under my pull out lint filter that I had to remove then pry up the top, stiff putty knife might be needed. Mine just pull up. Then I had one screw on top left inside front cover and once that was off the door can be lifted slightly on the left side then swung open. Use a bungee cord or someone to hold the tumble barrel up. You should be able to see everything from floor level.
Aug 11, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
