Question about Electrolux E23CS75SS Air Conditioner
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
We have a portable air con unit (Electrolux Kelvinator EPK09CRN2A) which is leaking water out the front onto the floor. No water makes it into the water tray. We recently were given it by a friend and transported it on its back in the boot of our car. Would this have caused it to leak? How can we fix it ourselves? many thanks
    Top Expert:
  • Electrolux Master
  • 34,208 Answers
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Posted on Nov 28, 2012
justaplumber
  • 98 Answers
SOURCE: Electrolux air conditioner
Tell me the model no. and I will find info or a new manual for you.
Without this info I cannot help you as there are many different coolers made by electrolux.
Posted on Dec 23, 2007
  • 534 Answers
SOURCE: Water Leakage
sounds as if your condensating drain is clogged. This drain is connected to a drain pan in which your eveporator coil is in. The filter material may have gotten into this pan and covered the drain hole. The way to check is to open the area where the coil is located and look at the tray this coil sits in. This tray should have a hole right in the corner of it. You may need to get a shop vac with a small hose attachment and use it to remove the water in this pan in order for you to see this drainage hole. You may also go to the drain where it is located on the outside of the house (this drain is located by the a/c unit outside most of the time) and using the wet vac, put the house on the end of the drain pipe and have the vaccum pull out alll the debris this way. Good Luck
Dave
Posted on Jul 30, 2009
ivan_gueorgi
  • 128 Answers
SOURCE: after changing batteries on the remote the number
1.restart device from cable.2.remove battery from remote cont.and try again
Posted on Dec 07, 2009
  • 141 Answers
SOURCE: I hve an electroluc air conditioner RO31D model
usaly you will have two screws on the front of the unit you would take them out unplug the unit first and then pull it out
Posted on Apr 08, 2010
  • 3 Answers
SOURCE: Electrolux Kelvinator - Unit on defrost
Check the defrosting sensor on the coil or the solanoid on the reversing valve.
Posted on Jun 07, 2010
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
I have a kelvinator Electrolux split air con model r51k/bge it doesn&#39;t seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Not cold enough
An air con unit of any make should never need to be regassed if initially installed correctly. If it needs regassing, there must be a leak. You would have to find the leak and repair it before regassing, or it would be the same as pumping a tyre with a slow puncture. Generally most simplex systems use around 750 to 800grams.
May 09, 2009 | Heating & Cooling
Heating & Cooling Logo
474 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
