Technics amp sa-ex100 power audio module
Need a power audio module for a Technics sa-ex100 amp
SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Posted on Feb 24, 2008
SOURCE: I have a Technics SA-GX470.
I have not solved it yet. I did find a similar schematic of another model. I have gone over the entire board checking connections first. What I see is the minus 14 volt regular running very hot. The voltage is OK but there is something drawing a lot of current. The plus side is cool. I am in the process of looking at all the loads on it but believe it may be the main power module. This unit has two modules with the main one for the left and right speakers and another that is for the center and surround speakers. It is cool and guess the the main one may be bad. Panasonic is the only source for this one and that is doubtful. The prices I have found is around $60 and a little expensive to buy and just try. I am going to make sure it is the problem before I recommend they spend that much up front. Technics is a low end Panasonic product and I have found this to be a very troublesome unit as well as others. It's design is complicated as all Panasonic products are. I worked on this unit several years ago and the same problem went away. I suspect one of the output transistors in the module has gone rendering the whole thing bad. Whatever happened to a simple transistor replacement. I will keep you informed.
Posted on Nov 15, 2008
SOURCE: technics sa-ex700
Hi,I have the same receiver...and what you mean by "the two stk".....i have the operation manual whith the specs....
Posted on May 24, 2008
SOURCE: i need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Posted on Feb 01, 2010
micromatikal
  • 2777 Answers
SOURCE: Need copy of manual for a Technics receiver
This was pretty tough to track down but I found it just for you!
http://service.us.panasonic.com/OPERMANPDF/SAEX510.PDF
Please make sure you rate my answer 4 thumbs up,
it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 21, 2010
Technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Jul 22, 2010 | Technics SA-DX750 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Technics sa-ex700
Mar 18, 2008 | Technics SA-EX700
Hi!
Jan 15, 2008 | Technics SA-DX950 Receiver
71 people viewed this question
 Grubhead
Grubhead
