Question about Dryers
How do I level the dryer
I took screws out of the back of dryer thinking that I could open the back panel. I found that the problem was simply that the belt was off.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
  • 213 Answers
SOURCE: how do I replace belt on kenmore dryer 66512?
under the lint screen on the top of the dryer there are 2 screws. remove these screws. aong the edge where the front of the top of the dryer meet the top of the front of the dryer there are 2 clips. press in the clips with a putty knife to raise the top. look inside you will see 2 screws that go into the front of the dryer. remove thoughs screws and the front will lean forward and lift off. there you will be able to put belt around the drum, tension pulley and motor pulley
Posted on Nov 28, 2007
dragonsthatk
  • 547 Answers
SOURCE: I think I need a
try taking front off dryer you may find it easyer
Posted on Feb 19, 2009
SOURCE: Electric Frigidaire Dryer Model GLER341AS1
there are two tabs that hold the top cover on,they are a couple inches in from each side.push in and lift lid. inside front panel are two screws, remove them then pull front cover out and lift it up of tabs on bottom.once you get the cover off remove belt,the you will be able to see your mess. heating element mounts to back panel.there is a heat sheild that mountws to the back of the drum.then you lift the drum up and put three screws in the drum to the pivot plate on the back panel.
Posted on Apr 21, 2009
Maytag317
  • 1136 Answers
SOURCE: How do you remove the outside panels to get at the
Hi, There are 2 screws in the front panel down where the metal bevels in. Remove the screws and the front eill pull off.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
  • 4 Answers
SOURCE: dryer delt
the belt runs around the drum in the middle of it as you take the two screws out the back panel and remove the top piece of wood in the middle of the drum you will see a black band thats your belt and the motor is to the right of the drum at the bottom you can access this through the gaps on the bottom of your dryer try spraying some belt dressing on it if its squealing
Posted on Jul 16, 2009
Screws in dryer have wallowed out and need to be replaced
Go to hardware and get at most 1 size (3/16 up to 1/4) larger screw and a square washer and a lock tooth washer on the back side of the dryer and then re-tighten the new screws. Also, while you are at it, adjust the legs on all four sides to level the dryer, they simply screw in or out as needed. If you don't have a level get a plastic coke bottle and fill i/3 full. Put a board of yard stick on the machine from side to side, lay the bottle on it and adjust unitl the water is level, then do the same front to back..
Jan 22, 2014 | Kenmore 94802 Front Load Stacked Washer /...
Where is the heating element on an Admiral Dryer, Model ADE 7005AYW?
pop open the top and take off the screw on each side of the front panel on the inside and your element is on the back left corner.
Can't miss it
Apr 16, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Dryer Problem
What is the model number of your unit?
Nov 28, 2012 | Dryers
How i get my maytag model #mgdb400vq0 front panel removEd?
just wanted to add that i found the service manual underneath the control console. Simply removing the three screws in the back of the control console opened it up, and there was the service manual, which had very good details on how to take apart the dryer.
Jul 31, 2012 | Maytag Dryers
The drum does not turn smoothly and makes a griding sound. I am trying to take the back panel off and took all the screws out but can not get the panel off.
drum roller/glides just click on open my dryers cabinet:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 17, 2011 | Dryers
I need to replace a sensor kit on a whirlpool dryer model len2000pwo. should i go in from the back of the dryer or front/top!!! The part was in the dryer drum when i found it so im not sure the best...
Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Opening the cabinet for newer Whirlpool brand models starts at the control panel. Begin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit.
Proceed by removing the kick-plate. There are two spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kick-plate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
Dec 01, 2010 | Dryers
How do i access the back of a Model #MDE8600AYW - MAYTAG Dryer. i think i need to replace the drum rollers but dont think i can from the front panel.
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Apr 21, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
