Tried to upgrade RAM now computer won't boot up
I have just tried to installed an upgrade RAM on my Dell 8100. When I booted up there was a message that said, new RAM installed do you want to continue, and another message about set up. I chose "continue". However, computer was no quicker and when I looked at the system config, only one old memory was showing, not old + new. So I change the memory round in the slots. Wouldn't boot up. So I put the old one back and now that won't boot up. What can I do, can you help
  • Prashant Bharadwaj
    Prashant Bharadwaj May 11, 2010
    Were you sure that you had upgraded to the RAM that is of same rating as the old?
    Genius:
  • 1,913 Answers
Check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
Posted on Jan 10, 2009
  • 28 Answers
Be sure that the memory is seated in the slot good ....the new piece of memory you bought , was it the same type ....just looked up a Dell 8100 for the type of ram it uses and from what i can see it takes RAMBUS not the normal ram ...this must be installed in pairs to work...here is a piece from website Technical specifications:
Memory type: PC800 RDRAM (non-ECC)
Memory slots: 4
Memory sizes: 64-, 128-, 256-, and 512-MB non-ECC
Max. Memory: 2GB for PC800 RDRAM
Notes: Memory must be installed in matching pairs. All slots must be populated with memory modules or CRIMMs ('blank modules'). ECC memory can be used, but this will work as non-ECC if mixed with other non-ECC memory
maby you mixed ecc memory with non-ecc memory.
Hope this helps you
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Nov 11, 2009 | Dell Computers & Internet
Memory Upgrade Attempt Causes Computer Not to Post
Seeing as the message is indicating a problem at one of the timer checkpoints, fatal is probably an accurate description. You are most likely looking at a motherboard replacement scenario. I've seen improperly seated memory modules toast timer circuitry on old boards back in the days when most of the timing circuitry was constructed from discrete components, not entirely IC-based timing solutions, but I have never seen it happen on modern boards.
Apr 10, 2009 | Dell Dimension™ B110 PC Desktop
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Upgrade of Ram on Dell 8100
There are 2 possibilities here - either the slot is not working or the RAM itself.
First install the working 128MB RAM in both memory slots one after the other and ensure that both the slots are in good shape.
Next, install the other 128MB RAM in one slot and check if this is working good.
Your laptop can support a maximum memory of 512MB. If you looking for an upgrade, please call Dell Support. Even though it's little expensive and shipping takes a week, you can get a free after sales service and peace of mind. Moreover you get proper guidance from the experts.
Jan 10, 2009 | Computers & Internet
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Memory upgrade problems
Hmm if the pc takes DDR Ram , it should deffently take 512 sticks, have u tried booting the computer with just the one 512 stick ? or try putting the 256 stick in and 1 x 512 stick , test it that way with both sticks , some older computers there is a bios setting for upgrading to higher amount of memory, but in your case with DDR ram i dont think so , i mean it may be worth a shot going into bio's and load optimized defaults , press f10 to save settings, try one stick at a time after that , if still no go , there is a jumper pin on the mother board that u can move over a slot which will restet the bios, if u dont know this jumper pin or where it is, just remove the round battery on the motherboard for 30 seconds , then put it back in , try your new ram then , u will be asked to save settings on boot up , if it still dosent work the ram is either faulty or incompatible, alot of the time with Dell , HP /Compaq desktops there fussy with the type of ram they take, but if u ordered from dell it should have worked !! whats the brand name of the ram u have is it hynix? /HP this brand of ram has alot of issues with compatibility,
Nov 21, 2007 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
850 people viewed this question
David Payne
David Payne
