Question about Dometic Refrigerators
Dometic 2 way gas fridge - Dometic Refrigerators
  • 93 Answers
SOURCE: Start my fridge on gas
have you ever used it on gas normally theese frige have a glow coil to ignited the pilot is it a fridge in a trailer or in a house also the themocople may me defective not generating electricity i woul need more info thanks from gilles
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Posted on Aug 23, 2009
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
Sea Breeze
  • 4655 Answers
SOURCE: hello we have a dometic 2
Hello Peta, Has this just started to happen suddenly or happens when perfectly level? I see that just a slight movement from being parked and level to a change where your Dometic Refrigerator may be leaning slightly. May be better to list or go to the reasons=> Why They Fail page full of reasons and from the sound your falls under a Leaks on the left side of this page. Anyway you will have a lot more answers and Technical Data and User Manuals listed by clicking at the top of their page=> sea_breeze_12.gif
http://www.gasrefrigeration.net/Why%20they%20fail.htm
Hope this information was able to help you, Thanks, Sea Breeze
Posted on Apr 16, 2011
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
My dometic fridge will not turn on
May 14, 2010 | Dometic RM2852 Refrigerator
Dometic rm 2607 makes a gurgling sound when started in a/c or lpg . no cooling, in fact the inside of fridge heats up.help ? thanks
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
Jul 08, 2009 | Dometic CS-200 Wine Cooler
Mar 15, 2009 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
