Shifts into drive too early, torque converter locks and unlocks quite often between 50 and 60 mph,
The bolt pattern for a 2007 Dodge Dakota Quad Cab should be depicted in a diagram on the owner's manual of your vehicle. You can access the owner's manual for your 2007 Dodge Dakota Quad Cab online at the Dodge website. ------------------------------------------------------------------------------
autel maxidas ds708
SOURCE: 2007 Altima automatic door locking
I consulted a Nissan master technician on this one, the Altima does not have auto locks, other owners have posted your same question as well and the experts answer is the Altima not equipped with this feature.
SOURCE: torque specs. for outer tie rod ends for 2006
Tie rod end is 35 ft. lbs. Pinch bolt for the lower ball joint - 105 .I hope this helps you
Testimonial: "thanks for the help"
SOURCE: 95 suburban with 4l60e and manual transfer case.
sounds like a solenoid problem or trans module,
