Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Refrigerator side vents top and bottom fill with ice gs6shaxmloo
No air circ fan still works its a whirlpool conquest gold
  • Anonymous Jan 12, 2009
    Ice blocks the top cold air feed from the freezer.
    Clear the ice and it blocks within 24 hours.
    Fridge door is secure and not left open. Fridge not excessively loaded.
  • 958 Answers
SOURCE: Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Posted on Feb 12, 2008
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
Posted on Jun 28, 2008
SOURCE: Refrigerator Whirlpool Gold Conquest (Side by side)
the ice maker is of a poor design. There is a wheel that essentially is the mechanical timing device of the icemaker. The shaft in the wheel is of poor design and it breaks leaving a non-functioning useless ice maker. Whirlpool does not sell the wheel & shaft assembly - you have to virtually buy a new icemaker. Takes about 10 minutes to replace. Charge for the part = $107; charge for the labor = $175
Posted on Sep 02, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
  • 1218 Answers
SOURCE: My icemaker will no longer make ice. It just
Good day,
If the freezer is working at it's normal temperature then follow this procedure to get the ice maker up and running.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jun 13, 2010
Ice maker leaks water-whirlpool GD5SHG
please check fill valve as it could be open. also check if supply tube at the back in the freezer is plugged with ice. check if the fan running in the freezer
May 13, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator not cooling
A common problem is the plastic sliding baffe / air diffuser breaks in the closed position or, the freezer side of the vent is blocked with ice.
Have a look on utube for air baffle / diffuser fix.
Dec 19, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Upright side by side. Refrigerator is getting warmer. Fan/vent on top is blowing okay. Vent at bottom left-above the bin-does not blow. Is it supposed to blow or is it just a vent? Coil is clean. ...
inside your freezer behind the vent if you stick your hand on the inside you should feel air blowing if not then the fan is gone if the fan is slowly making revolutions then you should replace also you can find the part at marcoe appliance parts or allbrands appliance parts they willmail directly to your door hope this helps plz write back if it is not your fan inside the freezer
Jul 25, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Top part of refrigerator cooling but not the bottom; please help
Defrost the freezer completely. Use boiled water in a pot to make it faster. Frost built up inside the freezer is blocking the vent that lets cold air in the fridge. Good luck
Feb 11, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold GD25DF FRIDGE NOT COOLING FREEZER WORKING FINE
Clean out the coils at the very bottom of the refrigerator from all of that lint/dust buildup it makes your system inefficient
Aug 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fan Noise
There should be 4-6 screws holding it on. They may be covered with plastic plugs. just pop those out.
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
