Question about Kodak A Ektagraphic 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector
Kodak Ektagraphic AF -2 carousal not rotating
    President:
  • Kodak Master
  • 412 Answers
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Posted on Jan 15, 2013
  • 412 Answers
SOURCE: Just purchased a Kodak Ektagraphic AF1 &
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Posted on Nov 03, 2010
  • 412 Answers
SOURCE: I'm having trouble changing the bulb in a Kodak
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
Posted on Nov 12, 2010
  • 412 Answers
SOURCE: kodak ektagraphic AF 1 reverse does not work -
If there are no broken components of the slide change mechanism and it is only an adjustment problem, do the following:
1. Remove the bottom cover
2. At the front of the projector (near the elevation wheel) you will find (2) 1/4" head screws going through black rubber grommets. Loosen the screw slightly.
3. Next to the screws you will see a cutout in 2 pieces of metal that when looked at together, resemble a diamond shape.
4. With the projector on in FAN mode only (NO LAMP!), simultaneously press the reverse button on the side of the projector and with a flat-blade screwdriver inserted into the diamond-shaped slot, twist gently to move the plate the 2 screws go through up or down until you get cycling in reverse. If you go too far you will get buzzing, which will indicate that the solenoid plunger is bottomed out in the solenoid coil. Once you get acceptable reverse cycle, tighten the 2 screws gently and turn the projector right-side up. Verify the correct action in both forward & reverse cycle. Adjust further if necessary. If OK, tighten the 2 screws and re-install the bottom cover. You're done!
Posted on Nov 22, 2010
  • 412 Answers
SOURCE: I need a instruction manual for the Kodak
I believe they still have a .pdf version in the Kodak website (www.kodak.com - then search on "slide projectors).
If you have a specific question, re-post that question & I'll give it a go...
Posted on Jan 04, 2011
  • 412 Answers
SOURCE: have a kodak ModelAF-2 Ektagraphic with worn out
There are a LOT of Kodak Slide Projector parts available, but I'm not sure about the one you are looking for. Check with: www.micro-tools.com
They have the single largest repository of Kodak slide projector parts in the world. Good Luck !!
Posted on Feb 01, 2011
Kodak Ektagraphic AF-1 will not advance or reverse
If the select button functions correctly, Chances are the direction lever in the mechanism is bound up or the Direction Lever Spring is broken. If the Spring is broken or the Direction Lever is bound up, the Index Lever will go out straight when the Advance / Reverse buttons are pushed - instead of moving out straight , then moving forward or reverse at a 45 degree angle.
The Slide Change mechanism needs to be re-built. The bad news is this projector was manufactured from 1976 to 1984. Kodak scrapped the repair parts in the early 1990's. Your best bet is to find a repair shop that has a projector that they can salvage parts for your projector from.... Good Luck !!
Dec 26, 2013 | Kodak Office Equipment & Supplies
I'm trying to find a manual for a Kodak ektagraphic AF-3
You should still be able to get an AF-3 manual (e-copy) from the Kodak website, or contact the George Eastman House Museum. Good Luck!
Jim
Mar 19, 2012 | Kodak Office Equipment & Supplies
Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
Have a kodak ModelAF-2 Ektagraphic with worn out worm gears for the tray rotation. Are the gears aviaulable and how much?
Jan 31, 2011 | Kodak Office Equipment & Supplies
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
Oct 19, 2010 | Kodak Office Equipment & Supplies
My Kodak Ektagrafic AF-1 Projector just stopped advancing and reversing while I was reviewing slides. I had been using both forward and reverse buttons. There is nothing stuck in it. It will not advance...
The KODAK Ektagraphic AF-1 was manufactured from approximately 1971 to 1981.
The problem you are describing is most likely a broken cycle solenoid "link". The "link" connects the cycle solenoid to the slide change mechanism. The "link" is made of plastic, which gets hard, brittle & could break over time.
Parts are still available, but the repair process is a intricate one. My best advice is to seek out an Authorized Repair Dealer.
Aug 11, 2010 | Office Equipment & Supplies
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
AF-3 carousel, lamp on but light guard prevents picture
Based on your description, I suspect the coil spring that tensions the "dark shutter" has either broken or has popped off it's mount. To be absolutely sure, take your projector to a factory-trained repair dealer.
Feb 13, 2010 | Kodak Ektagraphic III E Plus Slide...
I live in nyc where can i get replacement bulbs for the ektagraphic
The KODAK Ektagraphic ATS uses a 82volt, 300 watt ANSI code "EXR" lamp. You can order "EXR" lamps from Bulbman (www.bulbman.com)
Apr 19, 2009 | Kodak Ektagraphic III ATS Slide Projector
I need a instruction manual for the Kodak Ektagraphic AF-2 slide projector.....Where can I find one.....It is a 80's model with the round carousel at the top....Thanks...Susan
Apr 10, 2009 | Kodak Office Equipment & Supplies
Kodak A Ektagraphic 35mm 140 Slides Rotary Carousel, 80 Slides Rotary Carousel Slide Projector Logo
529 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
