Question about Ovens
Why is that light flashing on my oven and because of it I can increase my temp. Beyond 260 degrees.
  • 15,478 Answers
Unplug it for five minutes and see if the problem persists
Posted on Nov 28, 2012
  • 197 Answers
SOURCE: I have a De Dietrich oven which refused to heat up
Hi Ann, sounds like you need a new thermostat, get an approved engineer to check it for you
Posted on Sep 21, 2009
SOURCE: our whirlpool rbs245pd512 suffered through a power
your oven is now in C degrees, you have to switch it back to F degrees
Posted on Nov 01, 2009
EllaWatson25
  • 725 Answers
SOURCE: My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Posted on Oct 20, 2009
SOURCE: The actual oven temp is 20 degrees below the
I read the User's Manual/
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: oven turns on, but w2ill only heat up to about 120
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Jan 20, 2011
My whirlool oven will only heat up to 260 degrees
Sounds like the temp regulator switch, Remove / Replace the oven switch Some switches are adjustable by screw driver through a small hole in the caseing. NB disconnect the oven before trying to get at the switch. Some switches can be opened and fixed.
Jul 19, 2014 | Whirlpool Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Our Whrlpool Super capacity 465 oven will only let you preheat to 260 degrees. After 260 the display showing rhe temp. will not advance any higher. It will still broil when you push the broil setting but...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Whirlpool oven, however if you could post the complete model number I can speak directly about possible remedies instead of generalizing...
**Though it may not be necessary as I believe your disply may be set to Celsius (centigrade, like Canada and Europe) instead of Fahrenheit since 260C equals 500F thus it tops out at 260...most ovens will not exceed this temp unless in a self clean cycle.**
I suspect if you refer to your operator/owners manual it likely will instruct you how to change it back to display the temperature in Fahrenheit.
Thank you for choosing FixYa. I'll need to watch for your reply before moving forward.
Regards,
Macmarkus :)
Apr 28, 2011 | Ovens
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
