Question about Sanyo DP26640 LCD TV
Sanyo 26 in goes off and on by itself
Picture is great. Sound is great. The set will freeze with vertcal lines the the screen goes black after a few seconds the screen picture will come back on as normal and operate for an hour or two then repeat the freeze and sometimes not come back on. I have used the set as a computor monitor and it does the same thing. HDMI 1 input does not work so I use hdmi 2 for tv input. Can I repair with new part or is this a repair shop job?
    Top Expert:
  • Sanyo Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jul 06, 2017
shivam4529
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
javswr
  • 44 Answers
SOURCE: sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Posted on Mar 02, 2009
  • 105 Answers
SOURCE: Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Posted on Apr 29, 2009
  • 61 Answers
SOURCE: Sanyo dp42848 turns on, picture comes on then goes
Sounds like a loose connection to the display panel. Did you physicaly move it from the time it didnt work to the time it started working..
Posted on Nov 10, 2010
JulesPCaut
  • 702 Answers
SOURCE: problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Posted on Dec 03, 2010
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
No picture just vertcal colored lines and sound
What is the exact model number to your Poloroid TV?
Jul 12, 2012 | Televison & Video
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Oct 25, 2009 | Sanyo DP26746 26 in. LCD Television
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DP26640 LCD TV Logo
42 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
