Question about Behr 2002 BMW 325Ci Auxiliary Fan 02 BMW 325Ci
How to reset an oil light - Behr 2002 BMW 325Ci Auxiliary Fan 02 BMW 325Ci
  • 2,072 Answers
This is a computer fan section, try posting your questions under automobiles.
Posted on Dec 03, 2012
0% oil life
to reset the light with the doors closed key on press the gas down to the floor 3 times then the light should flash then its reset
Aug 27, 2012 | 2007 Chevrolet Cobalt Coupe
How to get change oil light to go off
Instructions:1) Check the oil. The light is a warning signal that you are low on oil or that the oil is not flowing properly. If the oil level is fine then the issue may be a reset button. Two different methods will allow you to reset the oil light.2) Turn the key to the on position. Do not turn the engine on. Press the accelerator pedal down three times in a five-second period. Turn the engine on. If the oil light goes off you have successfully reset the oil light. If it stays on you need to try the second method.3) Find the fuse box. This should be under the dash in between the steering wheel and the door. Open the fuse box and look for the reset button. Press the button until you hearing a beeping sound. It will beep three times. The oil light should be reset. Turn the engine and see if the oil light goes off. If the oil light stays it still has not been successfully reset.
4) Read the manual. The two methods above are the two most common ways of resetting the oil light. Your car may have additional options to try. If none of the methods resets the oil light then there is a different problem such as a non-functioning oil sensor. At this point you need to see a mechanic.
Parts Of BMW.
May 30, 2012 | 2005 Dodge Magnum
How to reset the oil life monitor
1994-99 BUICK LESABRE
CHANGE OIL SOON Light
1. CHANGE OIL SOON light will come on when engine oil has broken down enough to require changing. After changing oil, reset oil life display.
2. To reset light, turn ignition on. Open glove box to access oil reset button. Press and hold oil reset button in glove box for at least 5 seconds, but not longer
than 60 seconds. The CHANGE OIL SOON light will flash 4 times to indicate light has been reset.
May 14, 2010 | 1999 Buick LeSabre
How to reset the change oil light for a 2007 lincoln town car. Hitting reset button doesn't do it.
FIRST press and release the setup button to display oil life= xxx
then press and hold the reset button for about 2 sec it should then display oil life set to 100%
Just pressing the reset button when the change oil light comes on while driving will not reset the computer
Feb 15, 2010 | 2007 Lincoln Town Car Signature Limited...
How do i reset my oil light? my husband changed
TURN THE IGNITION KEY TO RUN WITH THE ENGINE OFF.FULLY PRESS AND RELEASE THE ACCELERATOR PEDAL THREE TIMES WITH IN FIVE SECONDS.YOU HAVE TO DO THIS MORE THAN ONE TIME.ITS NOT GOING TO RESET FIRST TRY BUT DO THIS PROCEDURE.UNTIL THE CHANGE ENGINE OIL LIGHT WILL FLASH WHILE THE SYSTEM IS RESETTING.TURN THE KEY TO OFF.WAIT A FEW SECONDS.START CAR UP TO SEE IF CHANGE OIL LIGHT COME BACK ON.IF YES YOU HAVE TO TRY THE RESET PROCEDURE AGAIN.
Sep 26, 2009 | 2006 Chevrolet Equinox
How to reset the change oil light for lincoln town car 2007
Press setup on message center,
press select for system check,
At oil life, press reset
Aug 14, 2009 | 2007 Lincoln Town Car Signature Limited...
How do I reset the change oil soon light?
Hi to reset the oil life monitor
turn the key on engine off
push the gas pedal to the floor 3 TIMES WITH IN 5 SECONDS
the light will flash then go out
May 12, 2009 | 2005 Chevrolet Equinox
2006 ford exsplorer oil light did not go off after a oil change.
In the owners manual, you will find reset procedures.
I found this for ya, hope it helps!
Please Rate!
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
Mar 03, 2009 | 2006 Ford Explorer
Reset oil life display after oil change?
THIS SHOULD BE IT.
How do I reset the Engine Oil life monitor and how does it work? TO reset To reset the Engine Oil Life monitor do the following:
Reset Oil life in NAV/DIC by (with car running) going to INFO>Oil Life>RESET
Press and HOLD until XXX turns to 100%
How does it work? The oil life monitor is a pretty sophisticated algorithm.
GM "The GM Oil Life System will automatically adjust the oil change interval based on engine characteristics, driving habits and the climate in which the vehicle is operated."
Feb 09, 2009 | 2007 Cadillac CTS 3.6L
Change oil light reset?
Hi Shady, here is the procedure for resetting the light.
Resetting Procedure
Follow this procedure to reset the GM Oil Life System™
  1. Turn the ignition to RUN, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds.
  3. If the CHANGE OIL SOON light flashes, the system is resetting.
  4. Turn the key to OFF after the light has finished flashing, then start the vehicle.
  5. If the CHANGE OIL SOON light comes back on, the engine oil life system did not reset. Repeat the procedure.
With Trip Computer
  1. Press the MODE button until the light appears next to OIL LIFE.
  2. Press and hold the RESET button for three seconds. The oil life percentage should change to 100 percent.
Nov 02, 2008 | 2002 Pontiac Grand Prix
Behr 2002 BMW 325Ci Auxiliary Fan 02 BMW 325Ci Logo
85 people viewed this question
Top Behr Computers & Internet Experts
David Payne
David Payne
Are you a Behr Computer and Internet Expert? Answer questions, earn points and help others
