Question about Mitsubishi Heating & Cooling
Need circuit board for mitsubishi aircon
Circuit board no. DM76Y559G01 ITS THE BOARD THAT MAIN WIRES ARE CONECTED TO IE.S1. S2.S3
  • 16 Answers
SOURCE: Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Posted on Apr 07, 2009
  • 8 Answers
SOURCE: Controller not working
The units were set up as master/slave by removing a jumper on the indoor board of the 0V unit. The CENTRALISED CONTROLLER display was removed by changing one of the indoor boards dipswitch settings.
Posted on Jun 11, 2009
  • 582 Answers
SOURCE: i need a circuit board for a Panasonic CU E7GKE
IF ALL YOU NEED IS THE CIRCUIT BOARD TRY A1 PARTS THEY HAVE JUST ABOUT EVERYTHING AND AT VERY GOOD PRICES
Posted on Aug 10, 2009
  • 57 Answers
SOURCE: I installed a Mr. Slim system and 2 of the 3 units
sounds like you're missing a leg. check all fuses, you may have one bad one.
Posted on Jul 16, 2010
caroldon
  • 17130 Answers
SOURCE: I have a 10 year
Sadly this is a poor service without a proper sincere logical advice. To spend $2500 for a 10 year old set is surely too bad , as they have finally almost constructed a new set except the body/condensers.
In the first place I do not want to worsen your problem with giving an advice remotely and asking you to do the job after such a whole lots of spares are changed and spent. I presume these changes of spares were done assuming the fault without a confirmation, hence my advice is to present the matter with bills along with a legal notice to the Mitsubishi service manger closer to you so that a proper action will be taken.
You have spend a lot for this unit and it is not adviceable to spend more before the actions done earlier is justified.
All the spares that were changed can be reset one by one to see if there was a failure. Also you have not mentioned to the forum the initial fault of the unit except it does not work.
So even after the main boards were replaced the possible fault could have been the compressor. make sure that the capacitor to the compressor is good and the motor runs. If so the cooling is due to poor compressor pumping. Please decide if you need to replace and take another chance as I would advice you to get back the money for the spares put in and go for a new unit...... assuming the compressor needs a change.
Posted on Oct 22, 2010
How can i test marine gyrocompass out put synchro and stepper
SYNCHRO MOTOR HAS THREE WINDINGS LIKE A STAR SOMETHING LIKE A THREE PHASE SAY S1,S2,S3 AND ANOTHER TWO WINDINGS CALLED R1ANDR2 , WHEN YOU SUPPLY EG 110VAC ACROSS R1 AND R2 IT GIVES A SECONDARY VOLTAGE ON THE S1,S2,S3 , SO YOU CAN CHECK IN THE MULTIMETER AC RANGE ACROSS S1-S2,S2-S3 AND S3-S1 , YOU SHOULD GET SAME VOLTAGE ACROSS ALL THESE POINTS .....hope that clears the question
Nov 22, 2014 | Boating
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
How to set time
First lets get the buttons identified. Electronic 4 button watches are probably controlled by the same chip. Top left is the light button. Going clock wise S2 (Stop/Start), S1 (Reset), and S3 (Mode). Press S3 button (lower left) 3 times.- Tuesday flag and seconds should flash. Press S2 and Seconds will set to 00. Press S1 one time, Minutes flash and advance by pushing S2. Press S1 again and Hour digits Flash and S2 makes them advance. Continue through Date, Month, Day. When finished press S3
Nov 13, 2014 | Adidas Mens Furano Adp6036 Black...
How do I change the time on my watch it's an adidas ADH6057?
Oct 01, 2014 | Adidas Watch ADH6057
I have a ADP6013 digital watch. how do you set the time ?
Aug 23, 2014 | Adidas Watches
Wiring diagam for spit system mitishabishi airconditioner
S1 and S2 is the 220vac S3 is the commuicating connection to the outside airhandler. The solution is on the control board that handle the remote funtions
Jan 21, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
Wiring
Yes, S3 is the comm wire and it needs to be connected.
S1 Is Active
S2 Is Nuetral
S3 Is your talking wire if that makes any sense
Dec 31, 2008 | Mitsubishi MSZ09UN Air Conditioner
Heating & Cooling Logo
221 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
