Question about GE Profile Spectra JBP95 Electric Kitchen Range
Electric stove burner getting red hot at medium
5 Suggested Answers
  • 126 Answers
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a GE stove that has a red light for HOT SURFACE
The control switch for the right front burner is bad. A new switch will solve the problem.
The situation,while annoying is not dangerous.
Posted on Feb 18, 2010
  • 161 Answers
SOURCE: my electric stove will turn on but the it won't
either the power cord is shorted out or the voltage coming out of the receptacle is too low...reset the circuit breaker,it may be half tripped-the lights can operate at 120 volts,but the unit needs 240v to operate the burners
Posted on Mar 06, 2010
mrbobfixit
  • 259 Answers
SOURCE: My problem is the large burner on this stove tends
Replace the switch that controls this burner to get it back under control. This will solve your problem as the switch is what controls the burner temperature regulation.
Good luck!!
Posted on Jun 16, 2010
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
How do I keep the burners on at medium heat when I am making carmels so they get to the stage where they become caramels. My burners kept shutting off, so I had to turn them higher and when I got don
Is it the electric glasstop stove with the smooth top? If so, the burners aren't actually turning off. They're red until they reach the right temp and then they go dark to maintain the temp. If they stayed red the temp would keep climbing. I used one a while back and I remember it doing that. You didn't give much info, so that's my guess. I think most electric stoves do that to some extent, though. If it's gas, however, I'd call a repair guy.
Oct 01, 2017 | Kitchen Ranges
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
My problem is the large burner on this stove tends to do somewhat ok on anything below a medium temperature. If you turn the burner to medium it escalates to high and refuses to lower even when you put the...
Good luck!!
Jun 15, 2010 | GE JBS03 Electric Kitchen Range
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Wiring Wrong
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Jan 11, 2009 | Cooktops
Stove top
YOUR SWITCH IS BAD FOR THAT BURNER REPLACE THE SWITCH AND YOU WILL BE GOOD TO GO
Jan 07, 2009 | Frigidaire FEF351C Electric Kitchen Range
2 burners get red hot no low control ??
Change the burner 2 switches. if they dont turn down to low, then its the burner switch.
Nov 17, 2008 | Brown Stove Works EM610 Electric Kitchen...
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
GE Profile Spectra JBP95 Electric Kitchen Range Logo
91 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
