Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux 2000 vaccum no power to the powerhead
Brought a new power hose and handle for Electrolux canister vacuum 2000. The power nozzle will not spin.
LizDahl
  • 75 Answers
SOURCE: vacuum hose replace electrolux how to
Replacing the hose is probably going to be the next step. Heres the thing.... Even though the hoses are a bit pricey- I have found that if youy try to cut a couple feet off the hose you will tick of your wife. I am so used to the length on mine that if I lost a foot off it, I dont know how I would reach behind the couch.... Except to have my hubby install another ACV outlet.... Plus air leaks and crackages happen when you try to shorten the hose...... Good Luck!
Posted on Jan 14, 2008
  • 15 Answers
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
Posted on Apr 10, 2008
SOURCE: My electrolux canister vacuum roller does not spin even though it has power.
take the floor attachment and on the front where you attach the wand there's a rubber like cover take it out,then you'll see a screw that you would need a star key driver,loosen it and the cover comes off,you'll see 2 wires,black and red,on mine the red wire came loose,just reattach and put things back together and you're good to go.
Hope that helps
Posted on Dec 18, 2008
  • 430 Answers
SOURCE: remove hose from handle on old electrolux canister
BE careful here. Do not fish a coat hanger in the handle.
The original hose has a set of detachable handle componnets.There are two metal screws in the underside of the hand grip.Do Not pry. Once removed go to the suction dial area underside of the grip. Observe the plastic fingers near the dial. These must be reset in their " track " when reassembling the handle.
Gently insert a small flat screwdriver between the rubber wiring contacts and the plastic tongue wraps around the socket. this tongue which extends from the hose handle adjacent to the metal tube. Work you way back to the hose area carefully separating the "hand grip cover" from the hose handle itself.
Once apart remove the obstruction. Carefully clean the two brass rings looking for any pitting. If pitted, gently polish by rotating fine wet/dry sandpaper around the rings, then lube with vaseline.
The matching contact fingers on the handgrip cover should be cleaned as well and gently tensioned to put a bit more presusre on the contact rings.
Slide the handle ONLY onto the hose. Once in place the contact rings will be visible. Now you can work the handgrip cover back into place starting with the two tabs at the hose end below the contact rings. To seat the small fingers at the control valve gently click into place before reinstalling upper handle screws.
Posted on Sep 07, 2009
SOURCE: frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Posted on Oct 14, 2009
How do i replace the hose on electrolux epic series 6500 canister vacuum
Cheap fix: DuckTape around the connections will work great
May 10, 2014 | Electrolux Vacuums
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
I need a new power cord for the power nozzle on my Electrolux 2100 canister vacuum. The power nozzle has part number N115M written on the bottom. I have found the power cord for power nozzles PN6 and PN7...
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Electrolux power nozzle not working
the powerhead gets its power through a connector adjacent to the hose connection to the vacuum end. there's two wires embedded in the hose which make its way to the handle, pipe and powerhead. take apart the handle and see if you can read continuity from one end to the handle switch.
Aug 06, 2007 | Electrolux Guardian Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
81 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
