Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
HOW TO SLAVE SAMSUNG HARD DISK HM121HI JUMPER SETTING
voodoomox
  • 1689 Answers
SOURCE: samsung hard drive model number
if this is a samsung, on the actual HD, you will see the jumper labels like the one below.
Usually it will say:
M = Master
S = Slave
Cs = Cable select
but if it is not visible anymore and you have 4 sets of pins, then the slave may either be the 3rd or the 2nd if you are looking at it from the back.
if you have other questions just let me know.
Posted on Oct 02, 2008
Crankstart
  • 696 Answers
SOURCE: failure predicted on HM121HI, F1 to continue
The error you're recieving is a fair warning that the hard drive is about to die, if it were a "replace engine" light on your dash you would know what to do. Time for a new drive. If there's any dat on the old drive you need you have already comprimised it by re-installing windows, if so STOP using it and let me know your Country, state, city... from a different computer and I will point you to a data recovery specailist. If it's just a workhorse or you have it backed up, buy a new drive, re-install on it and you're back in business.
Chris
Posted on Jul 08, 2009
  • 113 Answers
SOURCE: I have a samsung 2.5
You dont need jumper settings for sata hard drive, the sata ports on *********** board have the configuration, just connect the new hdd to the 2nd sata port.
Posted on Mar 24, 2010
Current009
  • 135 Answers
SOURCE: Please advice me for the
hi,
Please check the below link.
http://www.samsung.com/global/business/hdd/support/userguide/support_setting.html
If you found the solution is helpfull please vote for me, Thank you.
Posted on Mar 21, 2011
Cannot see second drive.
I am sure your missing jumper setting.
so you should change hdd jumper setting.
how to change u r hdd jumper just visit this site.
http://itexpertinbd.blogspot.com/2012/11/hard-disk-problems-jumper-settings.html
Nov 11, 2012 | Computers & Internet
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
I need to know the jumper setting for my hard drive to set it to a slave
Here is the jumper settings for Samsung hard drives. Assuming that your hard drive is bigger than 32GB you have to use the "General Pin Setting"
Note that after changing the jumper, it's suggested to partition and format your hard disk drive.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Samsung Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Jumper setting for slave drive
there is no such master or slave setting when SATA is used.
it is mainly used to tell the motherboard which one is master or slave when connected with IDE cable (PATA).
you don't need to worry about it as you are using a SATA HD.
the boot disk priority can be set in the BIOS
press del or F2 after you press the power button on CPU. you will be put with the BIOS/CMOS setup. go to boot priority and set accordingly, there is also an option to set the default hard disk in case you have more than one HD.
Sep 04, 2010 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
I need jumper settings for samsung hd080hg/j drive
Setting the order of the hard disk drive (Master, Slave) Jumper Location There are three cases of the installing jumper(shunt) if the jumper is located in the middle of connectors as above.
They are Lower 32GB, Upper 32GB and With capacity limitation in upper 32GB.
MASTER
SLAVE
Feb 18, 2009 | Computers & Internet
New (used) hard drive
Just remvoe the cd rom and then try to install your hard disk. if it is detected than it means there is a problem of setting master and slave in jumper.
So just check again your jumper settings and read the front side description of hard disk for jumper settings.
Aug 13, 2008 | Compaq Deskpro 2000 PC Desktop
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
122 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
