Question about Engines & Components for Toyota Tacoma
Tacoma bellhousing the same as all toyota v6
Will a tacoma engine bolt up to camry both are v6 engines
    New Friend:
  • Toyota Expert
  • 83 Answers
No.
Posted on Dec 09, 2013
How to remove 2006 Toyota Tacoma v6 engine?
There is way too much info to write to do R&R's. You need to purchase a manual because this gives you the specs also. The money for it is well worth it.
Oct 10, 2014 | 2006 Toyota Tacoma
I think my 2000 Toyota Camry engine may be seized up but not sure what can do to know fo sure
Take out all the spark plugs, remove the inner right fender plastic skirt, put the trans in neutral, and with a socket wrench, try turning the engine by the crankshaft pulley bolt. If it does not easily turn, it is seized.
Apr 29, 2014 | 1993 Toyota Camry V6
Where is the thermostat located in v6 camry 1993 getting to many mixed reviews ?
On both diesel and gasoline engines, the thermostat is located in the water inlet housing connected to the lower radiator hose.
Jun 17, 2011 | 1993 Toyota Camry V6
How do I replace a knock sensor for a 1992 toyota camry v6 le
First, I would like to mention that most knock sensor codes are not caused by the knock sensors, but a mechanical problem with the engine. The knock sensors cannot differentiate between noises caused by mechanical problems like a bad pulley bearing, bad motor mount, noisy alternator bearings, etc. and spark knock. knock sensor codes are set when the computer has retarded the timing as far as possible to compensate for ignition ping (Spark Knock) and the noise still exists.
With that said, here are the instructions.
Remove the Intake Chamber assembly.
Disconnect Injector connectors.
Disconnect the heater hose from the Intake Manifold.
Remove the 9 bolts. 2 nuts, 2 plate washers and Intake Manifold assembly.
Remove right hand engine mounting stay and water outlet.
Disconnect the following hoses and connectors:
Radiator inlet hose.
Engine coolant reservoir hose.
Engine Coolant Temperature Sensor connector.
Engine Coolant Temperature Switch connector.
Ground strap connector.
Remove the 3 bolts and right hand mounting stay.
Remove the wire band.
Disconnect the water bypass hose from the inlet housing.
Remove the 2 bolts, 2 nuts, 2 plate washers and water outlet.
Remove the 2 gaskets.
Disconnect the Knock Sensor connectors.
Remove the Knock Sensors.
Dec 02, 2010 | 1992 Toyota Camry V6
1995 Tacoma: I have a 1995 Tacoma V6 3.4L. The check engine li...
Based on what you've written, I'd say you've got a bad radiator. Fix the leak and then see if it still overheats
Jul 08, 2017 | 1995 Toyota Tacoma
How i repair a knock sensor for toyota camry 93
hi first try this? unbolt knock sensor and clead both engine block suface and the brass surface of sensor then re bolt to engine block do not use any grease/lube make sure the wiring to sensor+plug are clean then recheck operation of sensor ? if no joy ? renew sensor
Apr 06, 2010 | 1993 Toyota Camry V6
Where is the termostat located for 92 toyota camry v6?
its at the end of the coolant inlet pipe lower LH side of the engine. This pipe is below the alternator running from the lower radiator hose to the thermostat housing on the engine. Replace the O-ring at the end of the pipe if you are replacing the thermostat. There are 3 bolts holding the thermostat housing to the engine block. Hopefully this helps!! please rate...thanks!!
Aug 14, 2009 | 1992 Toyota Camry V6
Power steering belt on a 94 camry v6
only 2 bolts. They are hard to get to at the back of the engine but one is the mounting one and the other is the locking one for the adjuster once you get them lose you can undo the adjuster bolt and take tension off of belt then pull it off and replace it.
Aug 05, 2009 | Toyota Camry Cars & Trucks
2006 Toyota Tacoma V6 engine oil sensor location
There is not enough flow at the sensor for a second oil filter. The sensor is at a dead end in the oil gallery. I recommend that you persue other options here. If you are concerned about oil contamination, don't be. There is nothing better than the factory filter...Look into adding more oil capacity; Look into an engine oil cooler; there is really no need for a second filter.
Sep 07, 2008 | 2006 Toyota Tacoma
Engines & Components for Toyota Tacoma Logo
119 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
