Question about Toshiba Satellite P15-S420 Notebook
Toshiba P15-S420 srtange power problems - Toshiba Satellite P15-S420 Notebook
  • paqntnt Jan 10, 2009
    the laptop has been running for a while with the AC connected then suddenly shut down. I was running a virus scan at the time and at times, the battery does not charge well
  • Terry Shackleton
    Terry Shackleton May 11, 2010
    That is not enough info to help you ...worst case is the motherboard is no good ...or could be power supply...or any component may be bad..
  • 28 Answers
Could be a heat problem with the shuting down ...check fan on bottom or side depending on your model and blow out dust with air can .
Posted on Jan 11, 2009
    Genius:
  • 1,913 Answers
Check in back side remove battery then clean it from dust then refix it.
Posted on Jan 10, 2009
I want drivers of satellite p15 s420
Hi and welcome to FixYa!
This link i am sending you is the direct page for downloads for your model of Toshiba.
Please click link and you will be directed to a wide variety of downloads to choose from.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556034&rpn=PSP10U&modelFilter=P15-S420&selCategory=2756709&selFamily=1073768663
Please rate this solution if it was helpful for you!
Thank you for choosing FixYa for your computer needs today! Please take a moment to browse our other help areas for your needs now and in the future! We are always happy to help and are here when you need us.
KittyTech
Nov 25, 2010 | Toshiba Satellite P15-S420 Notebook
Repair DC Jack in a Toshiba Satellite P15-S420 Laptop
Follow the link below, it is an illustrated guide to the disassembly of the P15. Pages can be changed at the bottom of each page shown. Just copy and paste the link into your web browser's address bar.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p15/removing-motherboard-1.htm
Aug 02, 2010 | Toshiba Computers & Internet
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
How do I change the battery on the motherboard? Toshiba p15-s420
That will require a soldering iron, and a another battery with the same numbers. It is not a user replaceable part. the unit will have to be disassembled to access the battery properly.
Oct 30, 2009 | Toshiba Satellite P15-S420 Notebook
Toshiba P-15 s420 will not start without disassembly
i cant get ur question clearly, clearify ur problem in deail
Mar 09, 2009 | Toshiba Satellite P15-S420 Notebook
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
Drivers toshiba Satellite p15 S420
Hi Ferchichi,
Try looking here, theres 4 pages of drivers available for your laptop. You may not have found it before because I believe it to be an older model.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556034&rpn=PSP10U&selCategory=3&selFamily=1073768663&selModel=556034|PSP10U
You may have to copy the whole of the link and paste it into your browser. Otherwise try this link (I've tiny url'd it for you)
http://tinyurl.com/5m5fyr
Hope this helps you out!
David
Nov 18, 2008 | Toshiba Satellite P15-S420 Notebook
Hard Drive Removal
You have to remove the DVD and after that you will see the HDD under metal shield held in place with 4 screws labeled M2.5X6. Screw to remove DVD was also labeled (F6).
If you don't know how to do it, i suggest to get on line the service manual for further info.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Toshiba Satellite P15-S420 Notebook
Toshiba Satellite P15-S420 Notebook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
