How to hook up KLH amplifier and speakers to 60 inch Samsung HDTV Plasma? Help!!!
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Use your rca cord, plug the red and white cord to the audio output jack of the tv then the other end to the auxiliary audio input of the amplifier to amplify the audio output of the tv.
Posted on Nov 28, 2012
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: 61 inch pioneer plasma audio hook up?
I checked on Pioneer's site and couldn't find literature for this model, but did find the product information sheet for a model PDP-614MX. It may be similar, but no promises. This model has no audio output available, but does accept several audio inputs. It shows speaker terminals on the bottom and claims a 9-watt output for each channel. Speakers that mounted on the sides were available as an option.
This monster was originally designed for professional use (stores and such) as strictly an output display device. Probably the best solution would be to use this to display the video, and run the audio output from the source (DVD, satellite receiver, etc.) to a separate amplifier to drive your speakers.
Posted on Feb 07, 2009
  • 8 Answers
SOURCE: hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
Posted on May 22, 2009
tvtek
  • 1284 Answers
SOURCE: 46 inch 1080/ 120 hz
Is the TV connected via HDMI to a cable box? If so then if you have a cable box made by Scientific Atlanta you have to go into the settings and look the Digital Audio out settings. If it is set for Dolby Digital the HDMI will have no audio. You will need to put it in the HDMI mode to fix that issue.
Posted on Nov 24, 2009
dave1645
  • 834 Answers
SOURCE: Buzzing noise from 42 inch Samsung Plasma TV
this is a comon occurance in theis model it is caused be loose laminants in the switching tranformer sometimes it can be fixed by covering it with clear GE silcone
Posted on Dec 01, 2009
On my klh subwoofer the high speaker output stop working the sub works just fine but when I hook up the other speakers to it they don't play at all. I know if I go and buy a receiver I can bypass it.
The speakers connections have to come from an amplifier with sound coming from it in the first place. Once connected to the unit the bass signal is then extracted from the signal and the rest of the signal sent to the main speakers. The KLH will not power the main speakers on it's own. The unit will only take the two main stereo channels, from an amplifier, the left and right then go to one set of inputs and they then come out of the other two outputs.
Dec 27, 2016 | KLH Audio Players & Recorders
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
No picture or sound on 60 inch samsung plasma 550 TV
The power supply regulator board should be checked. Check this link, and select the site named 'Electro-help'. All details are described there in detail.
Jul 30, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hook up speakers to 32 inch lcd hdtv
May 16, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Feb 07, 2009 | Pioneer PureVision PDP-610MX 61 in. Plasma...
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
60 inch phillips plasma
is this a philips or a samsung? either way it sound like a diffusion problem..have the v_set and the v_scan voltages set lower bu 15vdc
if this wont help it is time for a panel
Nov 07, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
