Question about Canon CLC 1180 Copier
Canon clc 1180 error code 071-0007
My printer giving this error sometimes it says paper jam in the transfer unit but there is no paper there , what could be the problem with the machine? please help
  • Anonymous Feb 23, 2009
  • 168 Answers
K you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Posted on Jan 10, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
Feb 27, 2013 | Canon CLC 1180 Copier
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
E073 0003
hello have a look in side the unit to see if you have any paper no mater how small stuck at the back of the transfer unit,and the transfer drum,if not try cleaning the connections on the back of the transfer unit.also check for a broken switch.
maybe just a good clean may do the trick.
hope this helps
Nov 14, 2012 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
May 25, 2010 | Canon CLC 1120 Color Copier
Certain papers, notably a transfer paper that I have used in other machines and have a lot of, will not stick to the drum properly which causes a 'jam' message: "Open front door, remove paper from drum"....
The paper on the CLC-1180 is held to the Transfer Drum by static attraction. Certain papers or media will not work with machine. One thing you can try is to check the flex the paper. Flex the paper and see which way it has the most flex. If the paper has more flex or bend in the Landscape direction load the paper in the Letter "R" direction, or Portrait direction (letter). If the paper is too stiff it will conform to curvature of the transfer drum and Jam.
Canon does not recommend the use of Transfer Material in the CLC series. Canon does have a recommended Heat Transfer Paper for Fabric item # 6094A082AA that will work with the copier.
Canon does recommend aftermarket transfer paper do the damage possible to the fixing rollers. It's possible you could get a Service Tech to adjust the Attraction charge in the copiers service mode to make this paper work better. The CLC 1100 series this very fussy about paper and some papers will just not work. The newer Canon Color copiers use a Transfer Belt which eliminate the bends and provide a straight through paper path much improving the performance with odd or heavy papers.
Mar 01, 2010 | Canon CLC 1180 Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1180 Copier Logo
494 people viewed this question
old marine
old marine
