Question about DigiDNA DiskAid
FileAid will not initialize.
Error reads "Please set registry key HKLM\Software\Microsoft\.NETFramework\InstallRoot to point to the .NET Framework Install Location"
  • DigiDNA Master
  • 2,878 Answers
Install .NET. Use Windows Update or direct from MS.
Posted on Nov 28, 2012
  • Odelia Villanueva Nov 28, 2012
    Your solution worked great. Thanks Jose.
Jit debugger error
jrotten65,
This error only pertains to Microsoft Visual Studio. Depending on which version of the software you are using, follow the links below.
Try updating to the newest release of Visual Studio
http://www.microsoft.com/express/
or use the Debugging Tools for Windows as an alternative
http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx
The Registry key HKLM\SOFTWARE\Microsoft\.NETFramework\DbgJITDebugLaunchSetting is set to 0x00000010 when JIT debugging is enabled.
I hope this helps.
Nov 04, 2012 | Dell Computers & Internet
Windows 7 PC, can't save my CK pages in .pdf
Reinstall Creating Keepsakes as an Administrator, as it reinstalls it will process your registry changes and should operate correctly
Sep 02, 2012 | Broderbund Creating Keepsakes Scrapbook...
How do you Set registrykey HKLM\Software\Microsoft\.NetFramework\InstallRoot to point to the .Net Framework install location
Its very dangerous to do this task manually.. it would be better to use a system utility tool like Reginout to fix the problem.
Apr 07, 2012 | ASUS N71JQA1 N71 Series 173" Notebook PC...
Error code 0x800B010E wont connect wireless to internet, trouble shoot wont work. path c:\windows\diagnostics\system\networking. content restricted. please help......
I am assuming you are running Vista or Windows 7. According to Microsoft this error is an issue with .NET framework. They suggest you turn off .Net, restart your computer, then turn .NET back on. Here are the instructions they give you.
Error code 0x80131700 is usually relevant to the old version of .NETFramework installed on your system. By default, the built-in version ofMicorosoft .NET Framework is 3.5.1. You can reinstall Microsoft .NETFramework 3.5 Service Pack 1 through the following steps:
Step 1:
a) Click the Start and type: "features" in the Search box.
b) Select "Turn Windows Features on or off " and click Enter.
c) Find Microsoft .NET Framework 3.5.1 and uncheck the box.
d) Restart the computer.
e) Repeat the step 1) to step 2.
f) Check the box before Microsoft .NET Framework 3.5.1.
g) Restart the computer.
Step 2:
If the issue persists, then I suggest you to perform the process by booting the computer in Clean Boot and check.
http://support.microsoft.com/?id=929135
Note: Follow the step 7 to restart your computer as usual.
Jul 02, 2011 | D-Link Computers & Internet
Hi, When installing the HP All in one 3210 under XP, I get an error screen part way into the installation title "issues stopping installation" which informs me that the files slbcsp.dll and...
regsvr32 SOFTPUB.DLL
regsvr32 WINTRUST.DLL
regsvr32 INITPKI.DLL
regsvr32 dssenh.dll
regsvr32 Rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 Cryptdlg.dll Open notepad, copy the above and save it as Securefix.bat. the double click on the securefix.bat file.
Read this support link: http://support.microsoft.com/kb/822798
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 18, 2011 | Office Equipment & Supplies
How to fix the JIT Debugging error?
Type "Regedit" in your Run menu and then click ok. Then navigate to the following path and delete the following registry keys.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\AeDebug\Debugger HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\DbgManagedDebugger
On a 64-bit operating system also delete the following registry keys: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\WindowsNT\CurrentVersion\AeDebug\Debugger HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\DbgManagedD
Hope this helps.
Apr 03, 2011 | Computers & Internet
Often when i click on something mozilla firefox says "not responding" and I have to wait all the time. Can you please tell me how this problem can be resolved? ......so that it "Responds...
Go to 'Run' and open 'cmd' · Type 'netsh' in command console then press enter · Then type 'winsock' and press enter and then type reset · Restart Your PC Another way is · Open Regedit · Navigate to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole · Find the Key : · Name: EnableDCO and set · Data: N · Restart Your PC · Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner reginout to solve it.
Nov 22, 2010 | Mozilla Firefox
Want to install Adobe 9 but keep getting Error 1606
Error "1606: could not access network location \Startup" occurs when installing Adobe Creative Suite 4 products or Acrobat (8 or 9)Check out this website for the fix to this issue.
http://kb2.adobe.com/cps/402/kb402867.html
Jul 30, 2009 | Computers & Internet
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Invalid syntx error
The cause of this issue
CAUSE loadTOCNode(1, 'cause'); This behavior may occur for one or more of the following reasons: • The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file: [HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]This Behavior May Occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0. • The following registry key is missing or damaged: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046} • One or more of the following files is missing, damaged, or improperly registered: • Urlmon.dll • Mshtml.dll • Actxprxy.dll • Oleaut32.dll • Shell32.dll • Shdocvw.dll
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem in Internet Explorer, follow these steps: 1. Quit all programs that are running. 2. Click Start, and then click Run. 3. Type regsvr32 urlmon.dll, and then click OK. 4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below): • Shdocvw.dll • Actxprxy.dll • Oleaut32.dll • Mshtml.dll • Browseui.dll • Shell32.dll Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
If the problem is still not resolved, verify that the following registry values are present and correct: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Thanks
Riz
Mar 21, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
56 people viewed this question
Top DigiDNA Computers & Internet Experts
David Payne
David Payne
Are you a DigiDNA Computer and Internet Expert? Answer questions, earn points and help others
