Question about Logitech Cordless TrackMan Optical Trackball
Left button is not responding unless you keep pushing it in. I air cleaned the mouse and this did not help. The unit is only 2 years old.
5 Suggested Answers
SOURCE: marble mouse left click isn't working well
Try this first. It worked for me.
1. flip it over
2. take out the four obvious screws
3. poke a hole in the sticker right above the "s" where "Marble Mouse" is written to find the fifth hidden screw
4. take out that hidden screw
5. gently unsnap the top from the bottom
6. clean whatever dust/dirt you find in there
7. put a small piece of tape on the bottom side of the left-click button that's not working (in my experience I'd clicked so many zillion times through the years that the plastic where the button made contact was slightly dented thereby making it to where my left-click button wouldn't work very well
8. put it all back together
9. pat yourself on the back for saving a bunch of money
10. celebrate w/ friends
Posted on Jul 02, 2009
odiebugs
  • 949 Answers
SOURCE: mouse ball stops responding, or responds
Send it back for repair, there is no fixing the chip in a mouse. Sometimes they don't work after one day.
So it depends on how much you paid for it depends on if its work ending back.
This is a great mouse, I only use logitech.
It does have a 5yr warranty.
Posted on Feb 04, 2010
SOURCE: right button doesn't work; single click with left button
left button doesn't work; single click with left button
Posted on Nov 01, 2010
Not responding when clicking
Make sure the batteries in the mouse are good, and that you're not trying to use it more than a few feet away from your PC. There should be some kind of transmitter plugged into your computer that lets it talk to the mouse--that transmitter may have a Connect button on it or something like that. you may need to push that one first, then push the button on the bottom of the mouse to make them communicate again.
Mar 12, 2010 | Logitech Cordless Mouse
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Keyboard works but Mouse does not respond
Restore your computer through a Restore Point. Choose "Start"in the lower left hand of the screen and look for system tools after that just follow the step shown.
Jul 31, 2009 | Logitech Cordless Desktop MX3200 Keyboard...
Marble mouse left click isn't working well
1. flip it over
Jun 17, 2009 | Logitech Marble Mouse Trackball
My wireless laser mouse microsoft 5000 quit clicking on the left button
Normal 0 Go to Control Panel and click on the Mouse icon.
Then select the Mouse button you need to program.
Hope this helps. Bud
Jan 08, 2009 | Microsoft Wireless Laser Mouse 5000
Ecoquest air purifier
i have a ecoquest, what you need to do is push the reset button AFTER cleaning. and the preform cleaning will go away.
Jul 22, 2008 | Ecoquest Air Purifiers
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Unresponsive buttons on Head Unit - Help!
i have the same problem and i can figure it out either
Oct 01, 2007 | Sony CDX-GT210 CD Player
Mouse left click button does not always make contact.
Hi RPM GUY, I have a couple of these too but what you?re describing is just the button wearing out from lots of use. Since it?s less than one year old it probably still under warranty, taking it apart would definitely void it. I would contact Microsoft hardware support and try for a warranty replacement. If you want to go ahead anyway remove the 2x batteries and you will see a screw inbetween. Remove it and the bottom half will come appart. Let us know if you have any other questions and please don?t forget to rate the post.
Feb 01, 2007 | Microsoft Wireless Optical Mouse
Logitech Cordless TrackMan Optical Trackball Logo
78 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
