Question about Bernina Sewing Machines
What bobbin size for bernette 680 - Bernina Sewing Machines
2 Suggested Answers
SOURCE: I don't have the instruction
Ok, I just figured this out on a friend's machine. On the top right there are three little metal rods sticking up. Put the bobbin on the middle one (coming out of the hole) and push it to the right. That switches the machine to the bobbin filling mode instead of the sewing mode. Then, pull the metal rod in the back up and place your spool on it. Loop the string around that metal disk on the top left and then into the bobbin. Press the pedal and it should work. I figured this part out, but now I can't tell how to insert the bobbin for sewing. Any suggestions?
Posted on Jan 26, 2009
Bernette 75, thread wraps around bobbin housing, the bobbin fits totally inside the bobbin holder
Clean out the bobbin area thorougly. The bobbin must be the right size. If it is too tall it will cause the thread to wrap around the bobbin. Make sure you insert the bobbin and check to see if it is higher than the bobbin.
Aug 06, 2017 | Sewing Machines
Does the bobbin case of a singer fit in the bernette 65?
No. You need to purchase a Bernette bobbin case for your machine. Check with your Bernina dealer.
Jul 18, 2017 | Singer Sewing Machines
Need Bobbins for my Bernette 200
I've found one site with the bobbins for the Bernette 200: http://www.thecolorfulworldofsewing.com/Bernette-100-and-200-Bobbins.html . E-bay has some listings for these bobbins. However, some listings were old and the bobbins were no longer available.
I hope this helps.
Feb 17, 2017 | Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Is the bobbin supposed to move on the Bernette Deco 600?
Could you please let me know how you got this resolved. I just got this same machine and I am wondering the same thing...it just stopped picking up the bobbin and I have never really looked at it before that but the bobbin does not spin as well
Jul 21, 2014 | Bernina Bernette Deco 600
The bobbin will move only when the thread is being pulled. The problem with your machine is that the timing has missed aligned. It will need service. 99% of all sewing machine misalign due to continued use.
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Bernette 56, can't wind the bobbin thread, the spool not releasing the thread!
check the bobbin tension for the thread size you are using as it requires adjustment for different threads
Jul 06, 2014 | Sewing Machines
Why won't my Bernette 65 pick up the bobbin thread
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 14, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
I don't have the instruction booklet for my Bernette 680 sewing machine. I need to know how to fill the bobbin.
Aug 03, 2008 | Bernina Bernette 75
Sewing Machines Logo
42 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
