Question about Toshiba 42H81 42" Rear Projection Television
My toshiba tv does not have a remote and the volume cannot be turned down
It is model 43A61 TAC0175
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If the manual button does not work the tiny switch under it is bad.
Posted on Dec 22, 2012
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
  • 7 Answers
SOURCE: RCR4258 Universal Remote will not program on this tv
try rca.com/codefinder
Posted on Apr 07, 2008
johnnydiode
  • 647 Answers
SOURCE: I have a toshiba 43A61 need code that will work
That depends on the brand of your universal remote.
Check link it may help:
www.remotecodelist.com/
Posted on Nov 12, 2009
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
Not Available
unplug and replug in, does remote work?
Sep 23, 2007 | Toshiba 43A61 43" Rear Projection...
Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Nov 09, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
