Question about Weiser Lock GED1460X GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol
How to tighten a Weiser door knob - Weiser Lock GED1460X GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol
2 Suggested Answers
  • 11211 Answers
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Posted on Oct 19, 2009
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Mar 25, 2014 | Hardware & Accessories
Unlocking the door
Same issue. But I have Garrison instead.
Dec 29, 2013 | Deadbolt Weiser Powerbolt 1000 Keyless...
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Hi i have a weiser GA331P privacy door knob set in my bathroom door, and i have noticed that it can be pushed in and in the locked postion and when the door shuts it stays locked. I am concerned thay...
the weiser set should have a tiny hole in the knob or rosette around the knob. A paperclip or such can be pushed into the hole to unlock the door. That is the primary difference between a privacy lock and a security lock. Farmerbear at FixYa
Oct 19, 2010 | Garden
I need to find a mechanism for a door handle where the knob is situated in the middle of the door (like european doors) ...any ideas where i can find this type of door knob and mechanism?
I am in the same boat here, mine is also in the middle of the door and my doorknob is broken. Ahh. I can still re-attach and open if I play with it. I have talked with several locksmiths who don't know what I'm talking about. I know my bolt mechanism was made by "Weiser" Home was built back in 1975. Have you had any luck at finding any help with this? From end of door to middle is 18" and the mechanism is 19".
Mar 09, 2010 | Top Knobs M826 Door Pull
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
The kids locked the bathroom door and closed it... my
Oct 19, 2009 | Weiser Lock Locks & Locksmithing
Plunger sticks in when installing weiser locksets
Try enlargeing striker hole with tiny dremel electric sand drum disc. Throw bolt is binding and you may also try looseing all install screws and tighen each one at a tme as you test plunger each tighten until you have success,do not forget to unloosen throw bolt screws to.
Mar 19, 2009 | Hardware & Accessories
Weiser Lock GED1460X  GED1460X3BR Lifetime Polished Brass PowerBolt Powerbol Logo
81 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
