Question about LG 50PX1D 50 in. Plasma Television
LG screen out
My friend experienced the "POP - and screen went blank" problem a couple of months ago. He got an estimate on the repairs but decided to get a new TV instead. I have worked on electronics in the past and know a couple of people who have worked on similar TV's so figured I'd take a shot and try to fix it.
Yesterday we replaced the YSUS and ZSUS boards with (supposedly) new, working boards purchased from a local Zenith parts distributor. I turned the unit on and had a full screen of black and white static, then a few seconds later the left 2/3 of the screen displayed a pink/orange static.The right side of the screen was mostly dark, with a little dim static.
I unpluged the tv, waited 30 seconds or so and tried again, same result. I hooked up a known working antenna, same result. So I started fiddling with the remote. I think I was able to navigate the memnu with the remote arrow keys, because each time I hit up or down the colored static would chage a little bit (color or width). Blindly changing channels also changed the colored static but it mostly stayed on the left 2/3 of the screen. Also we did have audio, so I belive the tuner works.
I also changed the inputs with the remote (just to see what would happen, the only input attached to anything was the TV antenna) on some of the inputs we saw a 3"-4" vertical orange bar that every few seconds would change position, it kind of looked that a creen moving a display around to prevent burn out. Note that this orange would appear on the right 1/3 of the screen that had only dim static when I was navigating the menu or changing channels.
When we were instaling the new boards, we found one connector that had a pin bent down (possibly happened when being put back together at the shop when the unit was taken in for the repair estimate?) so we looked anround but did not find any other bad connections.
Anyway, sorry to ramble on but I am unsure of where to go from here. If anyone has any ideas that would be great. Otherwise I'll probably scrap the unit and try to Ebay the parts.
Thanks in advance for any advice!
  • g_cope Jan 13, 2009
    How do I determine which board is the "logic board"?
  • 24 Answers
Bad logic board.Always replace this along with y and z sustain boards.On some LG/Zenith sets they come as a replacement part kit.
Posted on Jan 10, 2009
  • tvrepairex Jan 13, 2009
    It is the small flat board mounted under the other boards that has the wide LVDS cable going from it to the larger signal board that has the tuner and other input jacks.The logic board also has white flat ribbon cables going to the zsu and xsus boards and to the bottom buffer board.
My SONY DCR-DVD405 Viewfinder has stopped working. When the LCD panel is closed, the viewfinder should show the view and the controls, but it is showing a blank grey screen. Please advise.
There is nothing user friendly on these, if your not factory trained on this type of repair then it should be done by someone who is. The view finder is a small LCD and is not meant to be repaired, but they can be replaced. Get an estimate and decide if you want to repair or live without it,
Jun 03, 2011 | Sony Handycam DCR-DVD405 Camcorder
J50 inch plasma went pop twice picture very distorted could smell something burnig warranty ended 1 month ago where do we stand
Present your case to LG customer care ASAP. So close to out of warranty, they may at least cover parts. you will almost certainly in the first instance be referred to an authorised repairer.
Jan 19, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
We bought vizio 32 in flat screen tv 2 yrs ago and one day the tv just went to a blank screen and will not come back on or off.
On the power supply circuit board some capacitors will vent (top will pop open), dome, or bulge. They can be replaced but the board is two sided and easy to damage. Having the caps replaced at a repair shop is the best way to go. If diyers try it the board can be damaged and then it would have to be replaced. Repair may cost a couple hundred dollars, but a new board can cost that alone, not including installation.
Aug 17, 2009 | Vizio L32 32 in. LCD HDTV
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
Oven was working great then it beeped and the display screen wen blank an the oven went off. Screen remains blank and now oven does not work
computerized? I think, if computerized, you should call for a repair person, and get an estimate. You can decide if it is worth the money to fix, or if you would rather go with a new one....weight your options!!
Good luck........also, check on line at:
www.howthingswork.com you can learn there too.
Aug 01, 2009 | Kenmore Ovens
The TV made a pop sound, then the video went blank. Audio works
i think the power supply went bad. this needs a lg repairman i would notr try to repair your self,lots of hi-voltage going on there
Jul 09, 2009 | LG 42PG20 42 in. Plasma HDTV
Toshiba 50HP66 went black after pop/crack sound
most units are made by someone else. your unit probably has LG parts. get the unit looked at by a Toshiba authorized servicer. they may be able to repair it at component level. the $900 you stated sounds at least $200 too high for board level repair.
Jun 19, 2009 | Toshiba 50HP66 50 in. Plasma Television
I replaced the Y and Z boards. Screen lights, but have new prob.
I have been through the LG TV runaround, and I can tell you that it isn't easy. On the same unit that you are currently working on, the part numbers of the parts you received may or may not be correct. LG (Zenith) uses slightly different parts for the same model, and it really is kind of a gamble on which ones are right. They do not keep track of parts by serial number, and on different TV's of the same model, I have been through 8 control boards (on one set!), 4 sets of X and Y sus boards (on one set), digital boards, and so on and so on. The people are nice in LG's tech services, and they will admit to the fact that it may take several of the same parts to get it right.
My shop has decided not to work on LG or Zenith for this and other reasons. The turnaround time to get a TV back out of the door is ridiculously long because of the wait time with parts going back and forth.
In short, you have the right boards, but they may be the wrong boards. Maddening, isn't it?
Hope this helps you...
Jan 10, 2009 | LG 50PX1D 50 in. Plasma Television
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
Dec 28, 2006 | NEC PlasmaSync 42MP3 42 in. Television
LG 50PX1D 50 in. Plasma Television Logo
397 people viewed this question
Computer Repairing
Computer Repairing
