Question about Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw
I am looking for a spark plug for my troy-bilt chainsaw model tb4218cc
The part number on the plug is9295-310502
  • Troy-Bilt Master
  • 14,417 Answers
Click here to see.
Posted on Nov 28, 2012
3 Suggested Answers
  • 1015 Answers
SOURCE: what kind of oil do
I would recommend valvolene srraight 30 weight unless you are using in cold,below 30 degrees F. Then I would go to 10W 30 Thank you. I have used valvolene products for over 30 years in all my four cycle equipment and I have never had an oil related problem.
Posted on Apr 21, 2011
  • 436 Answers
SOURCE: what weight oil does a
You need to use an SAE 30 weight oil on the E189
Posted on May 13, 2011
My Troy-bilt lawnmower model number 11A-A2BM711 HAS GAS HAS OIL doesn't start please help its only 3-4 yrs old
You need to pull the spark plug and verify it has spark, my guess is that it has no ignition spark due to a failed igniter unit or pickup coil.
May 03, 2017 | Troy-Bilt Garden
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Primer bulb does not work
if you have gas in the primer bulb its working. gas is sucked from tank to carb , out return tube to primer bulb and back to the tank from the primer bulb. most likely dirt in carb or hard diaphram not opening needle valve allowing fuel to be sent. carb kits are around 12 bucks . but carbs for troybilts are usually only 20 bucks. I would just replace the whole carb if the case. if the bulb stayed empty I would look for broken fuel line in the tank that holds the fuel filter. they rot and break off within a year or two.
Apr 20, 2012 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
I have a TB4218cc and need to replace the starter housing assembly. This shows to be discontinued. Is there anyplace to get used replacement parts?
the part number is MC-9228-MD0701 and they carry it at this website:
http://www.troybilt.com
Hope this helps
Handie Andie
Mar 27, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Where is oil drain for honda engine on troy mower?
I don't believe Troy-Bilt is any different than other chainsaws. There is no drain plug. You just turn it over and pour it out through the filler cap.
I did look at a diagram for Troy-Bilt and there was no drain.
Hope this helps
Handie Andie
Mar 25, 2011 | Troy-Bilt Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
HAS NO POWER AND DIES OUT WHEN GIVING MORE THROTTLE OR TRYING TO CUT
I have the same problem. Can't find my manual to look up trouble-shooting guide. Did following, but same symtom after:
1.) Clean air and fuel filter
2.) Replace gas lines with "tygon" tubing; check for kinks in gas lines.
Observations:
1.) Runs good for about 20 seconds then dies slow death. Starts and idles good.
2.) Air bubbles in primer squeeze bulb.
3.) Gas tank is pressurized.
My next trial and error mission:
1.) Fresh gas and oil mix.
2.) Remove gas and oil filters for bench test
3.) Replace primer tube (it is smaller than gas tube) so I cut ends and re-used old.
If you have pin-pointed the problem let me know. It sure seems like gas starvation.
Jan 13, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
The engine starts but the chain does not move even when the throttle is applied and then it starts to smoke the whine does not sound like it has full power either
Can you move the chain by hand? If not, the chain brake may be set or damaged so that the chain cannot move. Is the chain adjusted extremely tight? Is bar oil getting to the chain? The smoke is probably coming from the clutch which is trying to drive the chain. The chain should be adjusted so that the chain just comes up to the lower bar edge, but allows free turning of the chain by hand. Get back to us if you need further help.
Nov 03, 2010 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw Logo
152 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
