Question about Refrigerators
Making loud noise from the freezer side but every thing is working fine
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Open the freezer and press the door switch in to see if the noise is coming from the fan. If it is, see if there is any ice buildup on the back panel or behind it that the fan may be rubbing on. Keep me posted.
Posted on Nov 28, 2012
BarrettDenCo
  • 1772 Answers
SOURCE: I have a GE side
Sorry to read about your problem, I hope this helps you out.
it maybe your fan, going bad. or you have a ice build up, and its hitting the fan..if this is the case, you have a defrost issue. or a bad fan.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
HVACRH20
  • 237 Answers
SOURCE: My fridge makes loud popping noises
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
  • 72 Answers
SOURCE: Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Posted on Jun 15, 2009
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Samsung rs2530b refrigerator making loud noise...why?
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
May 28, 2012 | Samsung RS2530B Side by Side Refrigerator
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side refridgerator making noise and freezing
Feb 12, 2008 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
