Question about Water Heaters
Heatline c24 combi hot water going warm then cold burner runs fir 40 seconds and then shuts down and 10 seconds later relights.changed hot water thermister and still have problem
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
Posted on Dec 30, 2008
mrgrzz
  • 88 Answers
SOURCE: Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: ideal c24
sounds like the gas valve to me you need to see if the appliance is sparking 1st if it is then u need to check wether there is the right voltage going to the gas valve according to mi manufactureres instructions normally 240 volts ac if there is voltage then the gas valve is sticking get back to me after your findings
Posted on Jun 11, 2009
mrhotandcold
  • 248 Answers
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
Posted on Oct 21, 2009
heatman101
  • 43501 Answers
SOURCE: Pilot will not relight properly
The thermocouple needs to be replaced. That is what keeps the pilot light lit. The thermocouple is the little metal probe that sticks up into the pilot flame. Very easy to replace.
heatman101
Posted on Mar 26, 2010
Why does it take two bowls of water before water gets hot on combi boiler
The water isn't maintained hot (unless the central heating is on) in a combi boiler. you will, therefore have to turn the water on, which activates the burner. The burner will then have to heat up the heat-exchanger which then supplies the hot water through cold pipes. Once the pipes are warm, you will receive hot water.
Jan 29, 2015 | Water Water Heaters
Heatline vizo 24
Your cold water fill tube inside the tank is broken off near the top of the tank. Replace the fill tube.
Aug 26, 2014 | Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Water Heaters Logo
128 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
