Question about Husqvarna Viking 1
The top thread is getting very tangled in the bobbin case while sewing on my Husqvarna 183. It will continue to do this even after I have rethreaded top and bobbin thread.
I turn the maching off and back on before re-threading. I can never figure out what is wrong or how to fix it, but it will randomly start working again. Sometimes the bobbin case cover will pop open while sewing as well.
  • Husqvarna Master
  • 7,365 Answers
There could be something wrong with the hook and hook race.
try changing the needle
try a different bobbin
make sure that the bobbin is turned the right way in the bobbin case
check to make sure the top thread isn't coming off the thread take up
lever
the machine may also need to be check by a technican
Posted on Nov 28, 2012
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
My top thread is getting tangled up in the bobbin case area, even when hand turning the wheel with the bobbin and case removed; trying to fix a serious tension problem.
First, install a brand new needle.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct and that the bobbin is loaded and threaded correctly. Set the top tension to the midway point--you'll probably need to tweak the tension for your particular machine.
Bring the bobbin thread to the top of the fabric (manually with the handwheel). Then gently hold both thread tails in your left hand while you begin to slowly take the first couple of stitches.
If you are still getting thread barfs in the bobbin area, your machine may be out of time. Search for sewing machine timing or take it for service.
Understanding Thread Tension Threads
How and Why to Bring up the Bobbin Thread
Mar 12, 2017 | Sewing Machines
I am getting tangles on bottom of my work and an E7 error message.
try changing the needle--one for the fabric being sewed
make sure bobbin is turned correctly in the bobbin case
make sure top thread has not come off the thread take up lever
Feb 15, 2015 | Elna Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
Dec 15, 2014 | Sewing Machines
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 20, 2013 | Baby Lock Ellure
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
I have an Emerald 183 sewing machine.The bobbin thread is too loose. I can pull the top thread out no problem. I tried rewinding the bobbin thread, changing the needle and I do use the right settings for...
Clean any tangles from the bobbin area.
Always thread a sewing machine with the presser foot up so the thread can properly seat into the tension control.
Hand walk a few stitches to see if the thread still feeds too fast from the spool.
When thread pools (falls off the spool) a thread net will help - you can get these at a sewing machine dealer. I use to find them at fabric stores, but have not seen any lately with sewing/serging notions.
Mar 19, 2010 | Husqvarna Sewing Machines
Needle severs thread each time I start sewing
Take the thread completely off the top of the machine. Put in a new needle. Remove the bobbin. When you rethread the top of the machine make sure the presser foot (that rests on the fabric) is in the "UP" position and rethread the top. Also when you thread the top, put some "pull" on the thread as you thread it, don't just lay the thread in the tracks. You need to pull the thread with some taughtness through the machine so it gets into the correct places under the covers so you have good tension and good stitching. Then put the bobbin back in and make sure when you thread the bobbin case that the thread "clicks" slightly as you pull the thread into the metal tension area of the black bobbin case. Anytime a sewing machine breaks thread at the needle, you should unthread the entire top and rethread it because the thread can jump out of it's guides that are under the plastic covers and you won't be able to see it, but you will see very ugly stitching!!!
Nov 19, 2009 | Husqvarna Sewing Machines
Sewing machine thread nesting
I have fixed it now the bobbin case didn't seem to stay seated during sewing or tangling i should say!. I decided to change the needle and from then on everything worked fine.
May 04, 2009 | Riccar R650
Sewing Machines Logo
75 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
