Question about iRiver H320 MP3 Player
Iriver ihp120 hey, i have a problem with my iriver ihp120 it is getting a bit old but should still work. when i press the on/play button a red light shines from the top of the divice from the optical/line out jack. it is fully charged as the green light remains on when connected to charger. please help
Go to your settings menu. Switch optical output to off.
Posted on Apr 25, 2009
    Problem Solver:
  • 14 Answers
Back in the tools disk is an option for infa red input/output connection to your computer. Some how this option was activated, and it is looking for your wifi.
Posted on Oct 16, 2007
My iRiver does not connect to my PC but shows the unit is charging
Press Play to make it connected.
You can also turn USB Charging off via a long press of the NAVI button to get to the menu then it's under control
Jan 21, 2015 | iRiver H340 MP3 Player
Shuffle mode
Cut and modified from Douglas E. Levy at Amazon forum:
When you're in the Now Playing screen press and hold the Play/Pause button (right edge of screen). At the top of the slide-in menu you'll see Play Mode. Click Pause button again and scroll to "Normal" and choose it.
Jul 03, 2009 | iRiver Audio Players & Recorders
MODE/REC Button stopped working on iRiver IFP-790 digital audio player
I had the same problem. I got some electronic contact cleaner at Frys Electronics and sprayed a bit around the button, so that a little got inside. The button started working again instantly. If yu don't have contact cleaner you could first try a drop of denatured alcohol... I don't think it's as likely to work, but I also don't think it will hurt anything.
Arbie
Aug 04, 2008 | iRiver iFP-790 MP3 Player
**error** can't open this file???
Be sure you are using the latest version of Iriver Plus 3, to load your music. It automatically makes all the necessary conversions to put files on the player.
May 08, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Jan 05, 2008 | iRiver X20 MP3 Player
Iriver h340
Have you tried a program such as drive rescue (I got a portable version (for PC)from portablefreeware.com)
Likewise roadkill's unstoppable copier(google it, sorry no link) I don't know of Mac equivalents.
From memory the hard drive is a 1.8" Toshiba drive. If this is the case, you can get a USB enclosure to plug it into. (I got one on eBay for a similar situation with a faulty X-drive) You will need to pull the h340 apart before you buy it because there are a couple of pin configurations for 1.8 in drives. If you have to resort to cracking it open there was a video on youtube (I think) showing you how.
MisticRiver For iriver Enthusiasts would have more detail, I am going from memory and has been a long time.
Dec 19, 2007 | iRiver H340 MP3 Player
Wheres my music gone?
Just had the same problem myself with an ihp120 I just bought off ebay. Here are the steps I took:
1.  Prolific swearing
2.  Prolonged sulk
3.  Internet research
(I assume you have already been through these 3 to get to this stage)
4. I connected it to my PC via the USB lead - I could see all the files on the ihp120 and I backed them up to my hard drive.
5. In windows I right clicked the hard drive, to do a check for errors in the hard drive and to fix them -
It got about 80% of the way through, then the battery ran out - best to check that first.  When I turned it on again, 90% of the files were back and visible on the mp3 player.
So basically, back up the files, charge it fully, do a disc error check in windows.
Good luck
Sep 29, 2007 | iRiver iHP-120 MP3 Player
My iriver pmc won't switch off
make sure the hold button on the bottom is showing white, not red (locked) if that doesn't work, just pop the battery off and put it back in.
Aug 26, 2007 | iRiver PMC-120 Digital Media Player
Iriver doesnt play songs any more...
I had the same problem and i fixed it by updating the iriver firmware
Jan 30, 2007 | iRiver H10 MP3 Player
iRiver H320 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
