Graco pack play
Hi Carol, remove the fastener from the opposite side of the one that is missing and take it to a Home Depot or Lowes in your neighborhood. Some well stocked hardware stores may also be able to help. They have both metric and standard threaded screws and bolts and I believe the Graco uses metric. They have boards in the hardware department that should tell you which type you need.
It doesn't usually need to look the same to do the job but if they have nothing to help you out, you will at least know if it's standard (for example 10/24 x 1" which means the screw or bolt is size 10 with 24 threads per inch by 1 inch long) or metric (M5 x 0.8 x 1" which is the metric size closest to a 10/24 x 1") and the type of head, hex or bolt head or a screw driver head, Phillips or flat-bladed.
Armed with that information you'll be able to locate the exact replacement from hardware providers on the internet.
(If the head is unusual, take a picture)
Hope this helps,
The Tinker
