Question about Frigidaire FGES3045KF Gallery 30" Slide-In Electric Range - Stainless
Fridgidair Range Burner and Glass Top Problem
Frigidaire drop in Gallery range Model # FGES3045KFB installed by builder. Recently large Front Right Burner only gets real hot when on #8 or above, there doesn't seem to be a med-low to med-high level. Just low and high. The other burners appear to continue to work fine. We have noticed, after this started happening that the glass top has seemed to 'pop off' the countertop. It is raised about 1/2" from on the back side. Since, of course, this occured just after my 1 year warranty was up on both the builder and Frigidaire, I don't want to pay for a service call if it is something I can fix myself. Any ideas or recommendations?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the surface switch. Here is the part to order.
Keep me posted.
Posted on Nov 28, 2012
  • WS Hall
    WS Hall Nov 29, 2012
    Thanks Richard. I will look into that part and where/how it needs to be replaced. Do you have any words of wisdom on the lifted glass issue in the lower part of my post? This is the one that worries me the most.
  • Richard Roth
    Richard Roth Nov 29, 2012
    No, I have not seen that before. I will look to see if I can find any information on the glass popping up.
3 Suggested Answers
2coolrick
  • 560 Answers
SOURCE: ge glasstop oven
Check the element connections for good tight connections in both connectors. If ok, swap the element with one of the same size working elements and see if the swapped element works. If it does, replace the element. If it doesn't, the control switch or switch connections are the problem.
Posted on Jul 30, 2009
  • 760 Answers
SOURCE: How do you take the glass top off of an electric
See this GE link. Note the link to "click here to view diagram . Shows two screws holding trim plate on. You didn't give the complete model number of your unit. https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=ACCESSORY
Posted on Jul 04, 2010
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Gallery series convection oven delivered new yesterday.First burner that was turned on(front,right side) doesn't work. The rest do.
Hello Karen, thank you for your post!
Since you just received your unit recently, let's try resetting the range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the range on. If resetting the power does not correct the issue, your appliance could possibly have a faulty burner or a potential wiring failure to the burner. At this point, I would highly recommend contacting or visiting the manufacturer website to find a service provide near you and to verify warranty information. If there is anything else that I can help you with, please feel free to reconnect!
Best of luck!
Sep 19, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
A Broken Stove
whats the entire model number?? and you cracked the main top glass assy??? ill look up tha part for you, not a teribly hard job, but depending on glass may be expensive
Nov 16, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire FGES3045KF Gallery 30" Slide-In Electric Range - Stainless Logo
144 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
