Question about Lenovo ThinkPad R61 Notebook
My Lenovo R61 will not start.
I have tried starting it with and without the battery and it will not start-up. How can I manually switch to the A/C power without having windows being on?
  • Syd May 11, 2010
    Does the power light appear?
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
It lenovo R61 it has a password whenever you power on the notebook it shows you a lock, i av tried so many ways but i aint lucky
try opening the bottom compartment doors. look for a the cmos battery. If you take the cmos battery out(looks like a watch battery), short out the battery terminals for 60 seconds, this will likely dump any cmos locks/passwords, and default them. Worth a try . Please disconnect all power cords and take the main battery out first. Cheers
Aug 26, 2010 | Lenovo R61 T7300 Notebook
When i am starting my lenovo R61 which has vista installed, it is not starting at all. The AC power light and the battery lights get on along with wireless light. The other two lights will on and off after...
Drain Flee power
Steps
Disconnect AC adapter,
Remove Battery
Press and hold power button for 30 seconds.
Reconnect adapter and battery
Start your pc and go to safe mode and check power settings.
Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 10, 2010 | Lenovo ThinkPad R61 Notebook
Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Feb 27, 2010 | Lenovo ThinkPad R61e Notebook
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Lenovo ThinkPad R61 Notebook Logo
1,086 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
