Question about HP LaserJet CM1312 All-In-One Printer
Hp clj 3800 magenta background - HP LaserJet CM1312 All-In-One Printer
2 Suggested Answers
EPIJAB
  • 89 Answers
SOURCE: magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Posted on Aug 02, 2008
HP 4700 how to remove Purple Lines and dust
Defects in print are most often caused by a bad print cartridge and based on the color you mention I would look closely at the Magenta cartridge. You can clean the dust out with a lint free cloth, a swifter type dirt magent cloth works the best.
May 26, 2015 | HP Office Equipment & Supplies
My hp CLJ 1600 misaligment colors black go left yellow and cyan are ok and magenta goes right. I try calibration no effect
Hi bojan,
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
HP Printer Support
Feb 26, 2014 | HP Hewlett Packard LaserJet 1600 Printer
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
HP CLJ 5500
If you mean toner, you can probably do it, but most new printers have a memory chip on the cartridge which keeps track of toner. Adding toner will not change the count and the printer will ignore the new toner
Jan 04, 2014 | HP LaserJet 9500mfp Printer
59.52 error in hp clj 3600dn printer
This code means "An error occurred with the magenta print cartridge drive motor during startup orrotation."
I recommend the following steps.
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the driver PCA are seated correctly.
2. Replace the magenta print-cartridge drive motor.
3. Replace the driver PCA. 186
Here is a link to the service manual:
http://www.feedroller.com/store/Service%20Manual/CLJ3000_3600_3800_CP3505sm.pdf
Hope this helps.
Jul 31, 2013 | Office Equipment & Supplies
1.hp desighnjet 500 showing an exclamation marn on magenta printhead 2. error 59.99 on hp colour laserjet 3700
The exclamation mark means that the magenta printhead is already low in ink or have encounter a problem. Try removing and reinstalling the magenta printhead, if that didn't work, you will need to get a replacement for your magenta printhead since it could be low in ink.
Sep 21, 2011 | Office Equipment & Supplies
Hp clj 3600 error code 51.23 find the solution
51.XY ERROR
alternates with To continue turn off then on
A printer error has occurred.
X Description:
2 laser
Y Description:
0 Black
1 Cyan
2 Yellow
3 Magenta
Your error then comes from the magenta laser.
The recommendations from the service manual are:
  1. If the message persists, turn the printer off and then on.
  2. Reseat DC controller connectors J1022, J1026, and J1027.
  3. Reseat laser/scanner unit connectors J101A, J101B, J5001A, J5001B, and J5020.
  4. Replace the laser/scanner unit as necessary.
  5. Replace the DC controller PCB as necessary.
Mar 08, 2011 | HP LaserJet 3600n Printer
HP Q2612A Cartiridge refilling
YouTube - Toner Refill for HP Cartridges 2600, 3600, 3800 etc
Jul 08, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Magenta backgrounding
Jul 31, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet CM1312 All-In-One Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
