Question about GE GTWN4250DWS 3.9 cu. ft. capacity top load washer
I have a GE Washer GTWN4250DOWS. I was washing my son bedding and his mattress pad got stuck under the agitator. I have pulled and pulled on it. In need of help we dont have money to call a repair pla
The bedding was for a twin size bed
I washed some curtains and they got sucked up under the agitator. all i had to do was grab the agitator by the base and pull up firmly. it took a minute but came out with no problems. then i took a 7/16 wrench took the bolt off of the white plastic cap. My curtains were wrapped up inside there. put everything back together ..
Posted on Apr 26, 2015
    Top Expert:
  • GE Master
  • 9,472 Answers
Remove the dispenser cup on the agitator. Then remove the 7/16 bolt that holds the agitator on and lift the agitator out.
Posted on Nov 28, 2012
  • 3 more comments
  • jenifer Nov 28, 2012
    Where is the bolt at?
    My husband removed the cap and there is a fabric softner plastic casing under where the cap goes. He dsnt see a bolt?
  • Richard Roth
    Richard Roth Nov 28, 2012
    Remove the dispenser cup on the top of the agitator, then down inside the agitator you will see the bolt.
  • Richard Roth
    There may be a cover under the cap that will need to be removed as well. Here is a diagram of the assembly. http://cdn.appliancepartspros.com/images...
    Ty Richard we will give it a try.
the dr
  • 447 Answers
SOURCE: Agitator
Your problem is the agitator coupling is stripped. Very common on your washer. Just pull up from the base of the agitator to release it. Lip your fingers under the bottom and work it from side to side while pulling up. The coupling is the brown plastic piece attached to the transmission shaft. Remove the bolt and oring. If that bolt is rusty or oring damaged get a new one with the new coupling. Sometimes the coupler is real stuck on the shaft. Becareful not to damage the transmission shaft or the threads for the bolt to hold the coupler if you use a gear puller.
Posted on Nov 24, 2007
  • 52 Answers
SOURCE: GE Spacemaker stackable washer/dryer
You should go in through the front. Use a flashlight and look between the front panel and the top panel. You should see some clips there. Stick a flathead screwdriver into the clips to pop the top up and then remove the front. The front may be held in by screws, but since I don't know which model you have, look inside once you pop the top and see if there are screws. Then you should be able to remove the front panel and see the belt.
Posted on Mar 26, 2008
rickzilla
  • 706 Answers
SOURCE: drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Posted on Oct 11, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
My mattress cover is stuck under the agittor un my GE washing machine
We should branded products then we feel comfortable.
Sep 13, 2014 | GE Washing Machines
How do I get a mattress cover stuck under agitator out?
On the older machines, the cap on top of the agitator unscrewed & then the agitator could then be raised.
Sep 13, 2014 | Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
HOW DO I REMOVE THE AGITATOR FROM A GE WASHING MACHINE MODEL GTWN4250DOWS
Grab it in a choke hold and yank straight up. It should pop right off. There are plastic tabs that hold it to a coupler. Let me know if it gives you trouble.
Jan 28, 2013 | GE Washing Machines
Can I wash a bed topper
Though it depends on the type of the mattress pad, but most of them allows you to wash them. You must read the manufacture guidelines prior to washing your mattress pad. for more about how to wash a mattress pad, you can visit this link
http://www.howtocleanstuff.net/how-to-clean-a-mattress-pad/
Jack
Dec 26, 2012 | Laura Ashley Mattress Topper
What is a mattress pad?
A mattress pad is essentially a very thick sheet, or thin mattress, that is used as extra support to an existing mattress. It is a great shield between the mattress and your bed sheets, helping to minimize wear and tear to the mattress.
Jul 25, 2012 | Furniture
Towel stuck under the agitator..cannot be pulled out, agitator turns clockwise, agititor gets stuck turning counter clockwise
You will probably have to remove the agitator, There is a bolt on the top, take this off and lift off the agitator
sudinw8a1y.gifitator
Sep 22, 2011 | GE WPRB9250C Top Load Washer
Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Dec 25, 2008 | GE WBSR3140DW Top Load Washer
GE GTWN4250DWS 3.9 cu. ft. capacity top load washer Logo
410 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
