Question about Refrigerators
Hot tube comes on then panel goes out - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 28, 2012
My hot water comes out of the tap hot, then after a few seconds it goes cold, what could this be?
bad water heater probably . there is an inner tube that is called a DIP tube , they disintegrate with age
Dec 09, 2017 | Water Water Heaters
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Aug 19, 2015 | Refrigerators
HDMI makes black screen
IT sounds like the ccfl tubes (the bulbs that help light your tv) are going out. Think about replacing them. You'd need to take it in to get this done. Also, it may be cheaper just to replace the TV entirely, given the cost of replacing the tubes.
Good Luck!
Dec 05, 2013 | Vizio SV470M LCD TV
Turning the temperature knob all the way hot, air coming out goes cold. Turn the knob all the way cold and it goes hot for a minute and then cold.
MAYTEX INSIDE THE CAR GONE IF YOU GO ON U TUBE AND PUT IN temperature IN CAR NOT GETING HOT YOU CAN SEE IT ON THAT
Oct 04, 2013 | Jeep Cars & Trucks
Tv gets hot then goes black! Turn it off for a while get picture then goes black again!HELP
sounds like tube has gone if its an old one. if its getting hot get rid if it could catch fire
Jan 09, 2012 | Element Electronics Televison & Video
Hot water comes on but then runs cold after a minuate then goes hot again. The water appears to be hotter downstairs
If you have lukewarm water.. and at times it's hot.. then warm. or after running hot for a while and it cools.. chances are you have a cracked or failing dip tube.
The dip tube is just what it sounds like. a tube that delivers cold water to the bottom of the tank.. to mix with the hot water.. this keeps the hottest water at the top for faster delivery.
If this tube is cracked near the top.. or along it's length.. you may get some hot water.. then cold.. then warm..etc etc.
They are inexpensive to replace.. but as always exercise caution and follow proper procedure to relieve pressure, water supply and power/fuel before attempting a repair.
Generally this tube is inserted right where the cold water inlet pipe is on the heater.
A good plumber or water heater replacement or repair company could inspect fix and replace for a lot less than a new water heater.
Best of luck
Apr 10, 2011 | Heating & Cooling
Leaking water inside refrigerator thru openings
The defrost drain tube is clogged located in the freezer section behind the freezer back wall. use hair dryer and hot hot water to clear this tube.
Jul 05, 2010 | Refrigerators
I have a top-mount refrigerator that is leaking from the air vent
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. The following may help experienced do-it-yourself nuts, it is not for the faint of heart! I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Dec 16, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
2 problems: not enough hot water, and where the rubberized tube goes
It's my opinion that the tube goes in the boiler so that when the water boils, the steam will push the water up the tube and to the brew head. Without the tube, you will just get steam through the grounds.
Mar 10, 2008 | Krups Bravo Plus 872 Espresso Machine
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
