SOURCE: CHEVY 1500 TRUCK HEADLIGHTS TURN OFF WHEN YOU TURN ON SWITCH
If you have replaced the switch, and it is still doing it it sounds like you definately have a short somewhere in your wiring. On the other hand if the dimmer is in the turn signal arm ( forward bright back dim ) the problem could also be there in the dimmer switch, such as a short being caused by that dimmer switch being faulty.Auto Zone and Discount Auto Parts both test a lot of your electrical problems for free, and/or may have some knowledge to more accurately pin point the problem. Not sure about Pep Boys or some of the other discount auto part chains.
SOURCE: INOP low beam and high beams
The problem is the headlight switch itself - it's one of the most common failures on these cars. The part, brand-new, is about $158 from ECSTuning.com. Replacing it involves removing the airbag and steering wheel - not difficult but a little nerve-wracking due to the power of the airbag.
If this is something you want to tackle on your own, reply back here and I can give you a step-by-step on doing the work yourself. Or you can go to a shop/dealer and just have them do it. They'll probably charge you at least two hours' labor, even though it's a 40 minute job. Let me know what you would like to do.
SOURCE: all interior and exterior lights work except headlights...
BAD HEADLIGHT CONTROL SWITCH,REPLACE IT BEFORE IT MELTS YOUR DASH,THEY GET VERY HOT WHEN THEY FAIL
SOURCE: Jeep Headlights not working. High beam works
had the same problem on my 92....check under the hood on the drivers side,towards the front,there is a "junction box" with all of the lighting wires connecting from the switches to the lights.My wires were all corroded inside,so I cleaned the ends and bought a new box from the local electronic supply store.The problem has not come back.
Cheers
SOURCE: 2005 Ford Focus ZX3 SES, the blue high beam
It sounds like you are confused about how your headlamp system is supposed to work. The DRL does not run on the High beam circuit, it runs on the low beam circuit. The fog lamps are supposed operate with the park lamps and also with the low beams, not the high beams. From your description, I would say that your system is operating as designed and you are having trouble telling High from Low. (Don't feel bad, that is why high beam indicators were invented in the first place.)
