Question about Sentry Fireproof Safe
I have a sentry sfw123dsb safe with key but no combination ,how to open
    Scholar:
  • Sentry Expert
  • 170 Answers
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Posted on Nov 23, 2013
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
  • 76 Answers
SOURCE: How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
Posted on Jul 06, 2010
SOURCE: have sentry so310 safe lost
Lost combination can I still open safe
Posted on May 29, 2011
Open sentry safe key
contact sentry safes customer support or your local locksmith
if in Fort Lauderdale area try
Mar 23, 2014 | Sentry Safe SentrySafe Safe. Fire Safe 1.2...
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Insert your sentry safe key and turn it until the plunger pops out.
Pull the handle down; cracking the Fireproof Sentry Safe open.
Jun 06, 2010 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
31-10-31
Aug 25, 2009 | Sentry Fireproof Safe
I have a sentry safe with a key and combination lock i have misplaced my combination now what
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jul 13, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
I am unable to open my Sentry Safe S410 with my key. Do I also need a combination?
A good locksmith should be able to help you It sounds like your Sentry Safe is double locked. Now you need the key and combination to open the safe.
Aug 13, 2008 | Sentry Fireproof Safe
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking sentry safe open.
May 06, 2008 | Sentry Fireproof Safe
Sentry safe
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
Aug 25, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
578 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
